Old 11-22-2016, 04:36 PM   #1
Range hood light and fan, and lights above sink.
The range hood light and fan plus the lights above the sink do not work. Every other light works. Any troubleshooting help appreciated.
Albert1950 is offline   Reply With Quote
Old 11-22-2016, 04:45 PM   #2
Have you checked fuses?
Are they in a slide?
Sometimes the carrier under the slide that holds the wiring and propane lines can have problems and the wires get cut.
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 11-22-2016, 08:59 PM   #3
Tents2RV
Check your GFI breaker. You might be surprised to see what they tied into that circuit. I was.
c0nnd0r is offline   Reply With Quote
fan, light, sink
