Old 03-29-2016, 02:48 PM   #1
Rear camera R&R procedure
Hi folks
My rear camera has failed for the second time and I was wondering if anyone has removed theirs. I would like to replace it with a better one . I am out of my one year warranty now so I would like to replace it my self. Any help would be appreciated.
Thanks Chet
CARMAN is offline   Reply With Quote
Old 04-08-2016, 08:37 AM   #2
Carl17's Avatar
send Manufacturer an email about up grading.
Carl & Bette
2015 FR3
NEW YORK
Carl17 is offline   Reply With Quote
Old 04-21-2016, 03:43 PM   #3
Update, I found out that to reach the camera retaining nut and electrical connections all you have to do is remove the panel on the inside that bridges the ceiling and rear wall. It is stapled up their so you have to be careful when removing it. The camera is mounted by one nut that the electrical wires pass through the middle. My problem was the lead on the camera was bad were it plugged into the harness. I could move the wire harness around while watching the screen and when I got it in the right position it would work. So instead of replacing the camera I cut the plug out and spliced the wires together since I am out of warranty. It works just fine.
Chet
