Old 10-07-2016, 02:35 PM   #11
Gatch's Avatar
Because of this thread, I went to check on mine. This is what I found. I see from previous posts it is a metric M12 bolt, but how long should it be?
2015 FR3 30DS
2006 Wrangler X
Gatch is offline   Reply With Quote
Old 10-07-2016, 02:50 PM   #12
M12 x 1.75 x 35mm
DutchRv is offline   Reply With Quote
Old 10-07-2016, 02:59 PM   #13
On the road again...
Yikes!! I'm getting the creeper out right now and going under!! Thanks for the heads up, Boys. I just came off a 2400mi trip on some pretty rough pavement and lots of wind.
MMMH is offline   Reply With Quote
Old 10-07-2016, 03:25 PM   #14
Gatch's Avatar
Thanks DutchRv!
Also, while under there I am going to do the cheap handling fix (connecting the front and rear sway bars to the inboard holes instead of outboard). Every thing I have read said this improved handling performance. Has anyone heard of any negatives to doing this.
2015 FR3 30DS
2006 Wrangler X
Old 10-07-2016, 03:51 PM   #15
If it is 12mm, you can use a gr 8 1/2" x 1-1/2" bolt and gr 8 nyloc nut.
Old 10-08-2016, 01:52 AM   #16
Thanks DutchRv!
I did it. Great improvement!
Old 10-14-2016, 02:34 PM   #17
Former Full Timer
Duckogram's Avatar
Thanks DutchRv!
The only negative is on the front. If you do not use a longer link you could get clunking noise and premature bushing failure. Nothing catostrophic. I have 25,000 miles on mine since the adjustment was made.
The recipe for perpetual ignorance is:
Be satisfied with your opinions
and content with your knowledge.
Elbert Hubbard
Old 10-19-2016, 06:15 PM   #18
Looks like mine is broken as well. Thanks for the tip.
ID:	123448   Click image for larger version
Hampton is offline   Reply With Quote
Old 10-20-2016, 10:55 AM   #19
Follow up
Well, after crawling under the rig per my previous post I found the right side bracket broken as per pics by others. I have 15,000 mi. on this rig so it's a Ford warranty deal but I ordered the parts from my local Ford guy so I have them on board for the next time. The parts are cheaper than the fuel to go get it fixed for free. I will have Ford fix it, though.
Les, my local Ford parts guy, pointed out that the sway bar for the 24K-26K chassis is stiffer and actually costs $158 compared to $196 for the 16K-22K.
That, along with the CHF might be a good way to go. The Roadmaster bar for $500+ probably works well as it should for that kind of money.
sway
