Old 09-21-2016, 04:39 PM   #1
Carl17's Avatar
Exclamation Rear sway Bar check
Just a friendly reminder check bolts and brackets on rear sway bar. check mind every 6 months but its still happens.
Carl & Bette
2015 FR3
NEW YORK
Carl17 is offline   Reply With Quote
Old 09-21-2016, 04:45 PM   #2
AquaMan's Avatar
This happened to me when I was on my trip out west this summer. Top bolt came loose and fell out. Bottom bolt was loose and was able to unscrew with my fingers. Luckily I happen to look under the coach during a fuel stop, not sure why. Got a bolt from a repair shop at the Flying J and with the help of a 3lb hammer, was able to straighten out the bracket and get it bolted back up. I checked the rest and made sure all bolts were tight.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
AquaMan is online now   Reply With Quote
Old 09-21-2016, 05:00 PM   #3
HAPPY WHEN RV'ING
drivmsafe's Avatar
Always a good practice Carl. I check mine before and after every trip. If I'm out on a long trip, I'll check occasionally. So far, so good. Rather be safe than sorry.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 09-21-2016, 08:51 PM   #4
Makes me wanna get under it tomorrow and unscrew them, and refasten with locktite and torque wrench.
Thanks for letting us know!
DutchRv is offline   Reply With Quote
Old 09-21-2016, 08:53 PM   #5
DW's Retirement Plan
DaGrinch's Avatar
Ditto! Guess I need to get under the Sunseeker this weekend and check!
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life...
DaGrinch is offline   Reply With Quote
Old 09-22-2016, 06:58 AM   #6
wayne and sherry's Avatar
I replace my bolts with grade 8's and nylon locking nuts with a splash of red thread locker.
Sent from my iPhone using Forest River Forums yo
wayne and sherry is offline   Reply With Quote
Old 09-23-2016, 01:16 PM   #7
Doing this today. Any torque specs?
Old 09-23-2016, 04:43 PM   #8
Just a quick follow up, I did take my bolts out today and added locktite, but on my frame the nut is welded to the bracket that is welded to the axle assy.
Also can't use Grade 8s though, since these are (metric) M12 bolts. Mine were Class 10.9 which is strong enough. (similar to Grade 8 SAE)
PS. Thanks to the TS because mine were LOOSE
PS II. I love hanging out under the RV, I really do. Shouldve gone to school to be a mechanic
Old 09-27-2016, 09:51 AM   #9
edm
sway bar bolts
The spot welded nuts can be broken loose by backing out the bolt about one turn and hitting it with a hammer. Replace the bolt with 1/2" standard grade 8 bolt. If you were to put a trac bar on this is what you would have to do.
I put a SS trac bar on my 30DS and that is what had to be done. Sense installing the trac bar i have put on 15000 miles and nothing has come loose.
edm is offline   Reply With Quote
Old 09-27-2016, 08:50 PM   #10
I couldn't speak on the stock welded nuts as mine were already missing. That's why l used all grade 8 nylon locking with locker on the threads, and l cranked em as tight as l could.
sway
