Old 10-18-2016, 06:15 PM   #1
Refridge issue
Our fr3 2015 25ds refridge is popping the 15 amp fuse every time it is turned on, any ideas where to start looking for the issue? I am guessing we have a bad ground but all the wires are really confusing to a novice. I have been told that my extended warr. will not cover wiring issues? Anyone else having or had this? It took 16 months for this to show up. Oh, its doing this whether on 12 volt or 120
jogalot is offline   Reply With Quote
Old 10-18-2016, 06:25 PM   #2
SeaDog's Avatar
is it doing this when you are trying to run it on propane? Will it run on AC power (120V)
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 10-18-2016, 06:48 PM   #3
Ran out of 15 amp fuses playing around with it. No it will not run on 120. Hooked up 120 an as soon as the on/off button is pushed in it blows. Did not try it on propane only, need to get more 15 amp fuses. thanks
Old 10-18-2016, 06:55 PM   #4
Your element is shorted
2016 Flagstaff 23lb
Toddupton is offline   Reply With Quote
Old 10-18-2016, 06:58 PM   #5
Yea, you have a short. Start by checking continuity of the 120VAC heating element, check polarity of the 120 plug in. Check for loose wires at the fuse. Disconnect the wire bundle at the circuit board and check for loose or broken wires. I have seen a cat whisker (single strand of wire) that did not get inserted correctly short to another terminal causing issues. Plug the wire bundle back in securely and try again. Post back with your results. My guess a fraued wire shorting to ground.
donniedu is online now   Reply With Quote
Old 10-18-2016, 07:02 PM   #6
SeaDog's Avatar
I would not continue to put fuses in it. It seems like it may be the main control board which is powered by 12V may be shorted.
Retired Navy
AF&AM of Idaho
fridge
