Old 06-13-2016, 01:49 AM   #1
Edmo's Avatar
Refrig on propane
I'm probably repeating numerous threads on this subject but I think my refrigerator is not running on propane. Where and how can I check to see if it is working. Thank you as always
2016 Fr3 30 DS
Edmo is offline   Reply With Quote
Old 06-13-2016, 04:46 AM   #2
rattleNsmoke's Avatar
The easiest way is to remove your outside plastic refrigerator cover(the one with the two black plastic screwdriver slotted twist screws) and listen for the sound of the burner flame. If it's really quiet and the fridge is running on propane you'll hear it. Other than that some minor disassembly of the tin work to reveal the burner tube and see the blue flame is needed. It's quite simple and all that's needed is a screwdriver or two. And not the one with Vodka.
rattleNsmoke is offline   Reply With Quote
Old 06-13-2016, 07:12 AM   #3
We are plugged into our house power should the auto button be light I want the refrigerator to run only on are power we only owned this for a month still pretty clueless of what's going on
Tkotis5 is offline   Reply With Quote
Old 06-13-2016, 09:29 AM   #4
Our refrigerator only option is off or auto. While plugged in to electric it runs of electric. When disconnected from electric it automatically switches over to propane. Same for the opposite. While running on propane and is connected to electric is automatically switches over to electric.
Duane & Jan
2016 Crusader 295RST FW
2011 Toyota Tundra iForce 5.7 Limited Double Cab 6 speed automatic 4.10 gears
djeirlessr is offline   Reply With Quote
Old 06-13-2016, 10:25 AM   #5
Ok thank you
Old 06-13-2016, 12:02 PM   #6
Edmo's Avatar
Ha ha , I have two hands so two screwdrivers , one with the vodka
Old 06-13-2016, 12:03 PM   #7
Edmo's Avatar
I thought that if the check light was on that is when you have a problem. Mine is not lit but when I wee off of shore line and drove to my destination, the temp dropped in the refrigerator and was warm
Old 06-13-2016, 03:50 PM   #8
Our check light came on once I forgot to turn the propane back on after storage. We've never had a problem with temp on propane use though. You can try turning off your propane to verify the check light illuminates.
Make sure your temp slider is all the way up on your coil too. It does take a while to get it back to temp after loading it full before a trip. We usually load it full of groceries a day or two before we head out.
KansasFR3 is offline   Reply With Quote
Old 06-13-2016, 04:06 PM   #9
Georgia Frog Rally 2018
aceinspp's Avatar
Make sure to bleed air out of propane line other wise refrig may not light. Turn on the stove burners and light them to get air out of system then try refrig on gas. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
propane
