Old 07-19-2018, 11:55 AM   #1
Refrigerator Works on Gas Only
Hi,
I have a 2014 Forest River FR3 30D.
My fridge cools fine on gas but does not work on electric. Here are some notes:
1. All other electrical works fine. I have reset all breakers in the breaker box.
2. The RV is mostly level. Just slightly off level.
Does anybody have any ideas on how to troubleshoot further? Are there any specific fuses I should check?
thanks in advance!!
-Aaron
reportingguru is offline   Reply With Quote
Old 07-19-2018, 11:59 AM   #2
Did you check all of your GFCI circuits?
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 07-19-2018, 11:59 AM   #3
Mr. Dan's Avatar
You should tell us the manufacturer of your unit and its model number.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 74; booked = 12
Old 07-19-2018, 12:11 PM   #4
Thanks for the responses.
I checked the GFCI outlet in the bathroom and it is fine.
The fridge is Dometic. Model Number: DM2653
Old 07-19-2018, 12:23 PM   #5
Be sure to check for power on the outlet that the fridge is plugged into.
MtBiker is offline   Reply With Quote
Old 07-19-2018, 12:33 PM   #6
Thanks. I checked and there are 118 volts at the outlet that the fridge is plugged in to.
Old 07-19-2018, 08:17 PM   #7
lacoles
lacoles's Avatar
Check fuse on control board in outside cover or vent. One fuse for gas & one fuse for electric
lacoles is offline   Reply With Quote
Old 07-20-2018, 01:04 PM   #8
Mr. Dan's Avatar
The site team has pulled the second fridge issue which was inserted in this thread. It and its replies can be found here ==> RM3962RBX Fridge Problem.
Old 07-20-2018, 03:50 PM   #9
Just had the same thing happen to me. Pull the plastic cover off of the circuit board is located on the outside. Check the two fuses. If they're both good, replace the circuit board. About $90. I had to replace mine.
Good luck
Bill Poe is offline   Reply With Quote
Old 07-20-2018, 05:12 PM   #10
Had the exact problem with my XLR. Similar fridge. Replaced the thermistor and added a fan. Not it. Finally replaced the heating element. On electric now it gets in the high 30s and stays there. Easy job. All kinds of u-tube videos on installation. I think the element on Amazon was under 30 bucks. Good luck.
Bnrc73 is offline   Reply With Quote
gas, refrigerator
