Old 02-21-2017, 12:43 AM   #1
Replacing microwave
Has anyone replaced there tiny microwave with anything other than a domestic
/convection on a 2016 30 ds.I want to replace mine with a microwave/convection but heard the domestic DCMC11B.F is a bit of a lemon!Thanks in advance for any input.
lazbo is offline   Reply With Quote
Old 02-22-2017, 12:27 AM   #2
We had ours replaced and the installer used a Panasonic. Not convection though.
arh1967 is offline   Reply With Quote
Old 02-24-2017, 07:36 AM   #3
waiter21's Avatar
I replaced the Samsung in my Mirada. The Samsung would turn on by itself.
Replacing Samsung Microwave | 2001 Coachmen Mirada 300QB
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 02-24-2017, 07:53 AM   #4
WolfWhistle's Avatar
I bought and installed a Cuisinart counter top unit. I don't do anything the easy way, when I can make it complicated. It is deeper so I had to build a face frame and added a plywood bottom. I also lined the space with metal and added a vent above the unit.
This is an old photo when I first added it.
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 02-24-2017, 10:22 AM   #5
WW
You did a very nice job.Did you vent it out the roof?Looks good
Old 02-24-2017, 02:19 PM   #6
No, it is vented out the top of the overhead cabinet. When baking, there is some heat coming out but not that bad. Heat on the ceiling is quickly removed by Maxxair fans. I also added air inlet / vent underneath at the exhaust fan. To mount the MW, I fashioned sheet metal and attached to the bottom of the unit (3M double sided tape) You might be able to see, but the plate sticks out the front with a 90 deg bend down and screws hold it tight. I like the Cuisinart but one that doesn't require cabinet work would be what I would do now.
WW
Hyper Lite was sold
Old 03-18-2017, 02:49 PM   #7
does the microwave oven have to vent out the front of the unit?
bobquest is offline   Reply With Quote
Old 03-18-2017, 03:04 PM   #8
No, you set the vent fan direction before install. Real simple, 2 or 4 screws, lift it out and reset it in the direction you want air to vent. Mine came to vent out the front and I reset it to vent out the back and out the side vent of my RV
2016 Siverback 33IK
Old 03-19-2017, 05:39 PM   #9
When you come to a Y in the road... take it
WW
Hyper Lite was sold
Old 03-19-2017, 08:41 PM   #10
WW
2016 Siverback 33IK
