Old 05-26-2018, 06:26 PM   #1
Replacing Vent Covers/Lids
2015 28DS.
My 2 vent covers/lids have deteriorated and need replacement. (The other ones are replaced with second A/C and maxxair fan)
Camco makes several, anyone know which one to get? Or any other brand?
DutchRv is offline   Reply With Quote
Old 05-27-2018, 06:10 PM   #2
BatesMotel2's Avatar
1 Idea
I was considering installing a couple of these to make those new vent covers last longer.
https://www.campingworld.com/maxxair...SABEgJzX_D_BwE
BatesMotel2 is offline   Reply With Quote
Old 05-27-2018, 06:18 PM   #3
BillyBass's Avatar
I had to leave my trip after two days my skylight deteriorated and It rain for 12 straight hrs. My bed was be coming a water bed .So I came home and order one
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites 2018 11 nites
2015 16 nites
BillyBass is offline   Reply With Quote
Old 05-27-2018, 07:09 PM   #4
rk06382's Avatar
Originally Posted by DutchRv View Post
2015 28DS.
I went with Fan-Tastic Vent Fans & Ultra Breeze Vent Covers. I can leave vents open in the rain.
Amazon: Fan-Tastic Vent U1500WH Ultra Breeze Vent Cover.
I also installed the bug screens. I always hated hearing mosquitoes inside my vent.
Amazon: Fan-Tastic Vent U1550WH Ultra Breeze Bug Screen Kit
I watched this review before I purchased my FR3:
I have four Fan-Tastic Vent Fans with covers. Two are wireless as my DW can't reach the vents. I sometimes reverse one of the fans instead of opening a window.
Robert
2018 FR3 28DS
Samlex EVO-2212 Inverter/Charger | 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 600 Watts Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads
Retired: Alaska Army NG
rk06382 is online now   Reply With Quote
Old 05-27-2018, 07:16 PM   #5
Alright found it:
In white:
Camco 40155/40158 Polypropylene lids. Slides right on. Around $12. If you get this one you want to install a maxxair on top, because the polypropylene will deteriorate fast.
Camco 40168 PolyCARBONATE lids. $20 each. These slide right on as well and will hold up much better. I like these better because otherwise I think the roof gets so 'cluttered' with 2 AC's and 4 maxxair covers... Plus I never open these 2 vents, and have the camco insulation pillows in them...
Old 05-30-2018, 11:56 AM   #6
Easy replacement. Only thing I can say is the retention clip doesn't fit in the new Camco lid 'slide' so I didn't use it. Works as it should. Also nice to see the 12V hookups right there when working on the vents.
Before you take off the ceiling assembly cover, unscrew the 2 screen screws first, or the mounting rings will break under its own weight .
And don't forget the crimp the ends of the lid hinge so it can't slide off (reverse this step to take the old ones off)
ID:	173941   Click image for larger version
ID:	173942   Click image for larger version
ID:	173944   Click image for larger version
ID:	173945   Click image for larger version
ID:	173947   Click image for larger version
ID:	173948   Click image for larger version
cover, vent
