Old 04-29-2017, 08:01 AM   #1
Curiouser and Curiouser
Reservoir for hydraulic fluid for the jacks
Where is the hydraulic fluid reservoir for the levelling jacks located on a 2016 FR3? Do I need to change the fluid from time to time. Anything I need to be careful of when I do change or add to it?
Finch
2016 FR3 30DS
Finch is offline   Reply With Quote
Old 04-29-2017, 08:28 AM   #2
I asked that question a while back and someone was kind enough to point me in the right direction and even took a picture for me. I swapped out 1/2 of the fluid due to popping issues. It helped some. I need to go do another quart to see if it helps more.
Lippert power unit reservoir - 2016 FR3 32DS
mjessie is offline   Reply With Quote
Old 04-29-2017, 11:09 AM   #3
HAPPY WHEN RV'ING
drivmsafe's Avatar
It's in the compartment next to the propane tank. If checking the fluid level be sure the jacks are retracted. There is a level gauge attached to the cap. It's never a bad idea to service or change the fluid but, I've been told by more than a few sources that it is unnecessary unless you notice that fluid gets really dark. Only thing about adding.....don't overfill and don't spill (lol).
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 04-29-2017, 06:34 PM   #4
wayne and sherry's Avatar
What kind of fluid should be used for adding or changing?
wayne and sherry is offline   Reply With Quote
Old 04-29-2017, 07:00 PM   #5
HAPPY WHEN RV'ING
drivmsafe's Avatar
Dexron III or Mercon 5 ATF
Old 04-29-2017, 10:51 PM   #6
ATF is that so? I would have never guessed to use ATF. I almost bought some hydraulic fluid from the tractor fleet store but didn't because the color wasn't red.
Old 04-30-2017, 12:52 AM   #7
HAPPY WHEN RV'ING
drivmsafe's Avatar
That is so. You made a wise choice not buying that hydraulic fluid.
Old 04-30-2017, 04:19 PM   #8
See attached from Lippert on adding anti stiction fluid.. It includes what fluids are recommended. This is to reduce popping.
Old 05-03-2017, 10:24 AM   #9
Thanks to all
Thanks to all of you who replied. This was exactly the information I needed!
Finch
2016 FR3 30DS
Old 05-03-2017, 11:59 AM   #10
lippet support
594-537-8900 Customer service & tech services
acejohn6928 is offline   Reply With Quote
hydraulic, jacks
