Old 04-24-2016, 03:57 AM   #1
Reverse image backup camera
FR3 30DS 2016
Got the rig out of storage and have been checking out all the systems. I did notice that when putting the RV in reverse I get the message on the display "Image may be reversed" and it is. I don't remember this from last year, but at my age that could just be a senior moment.
Did I change something in the settings or is this the way it should be?
Thanks,
Bill
MrBill16 is offline   Reply With Quote
Old 04-24-2016, 06:23 AM   #2
Not a FR3 BUC but there are times our BUC is "Upside down or Left to right backwards" Real pain when trying to back for Hook up! There is a button for "orientation" our's is a I Ball BUC! Youroo!!
youroo is online now   Reply With Quote
Old 04-24-2016, 07:06 AM   #3
RSchleder's Avatar
Read the owners manual. We have a different model, however I'm sure they are all similar. On ours, there is a way to change it back by using the buttons on the unit. Unfortunately, also at MY age, I don't remember the exact procedure.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 04-24-2016, 07:13 AM   #4
The first thing I did was to read the manual. Unfortunately, there is nothing there that mentions reversing the image.
Old 04-24-2016, 07:16 AM   #5
Look at the bright side, senior moments equates to "learning new things". Like Yogi Bera said: "it's deja vu all over again". Have a good camping season guys, and drive safe.
Old 04-24-2016, 11:15 AM   #6
In our previous motorhome, there was simply a switch on the back that would switch it around. Not fun when reversed. Good luck
gschwane is offline   Reply With Quote
Old 04-24-2016, 11:20 AM   #7
I have a Tadi Brothers system. On the face of my monitor,there are several buttons. 1 On/Off, 2 Cam 1 or Cam 2, 3 An orientation button. It allows me to reverse the image or turn upside down. No damage will be done pushing the bottons.
You might have touched one inadvertently.
Good luck.
johng4706 is offline   Reply With Quote
Old 04-24-2016, 11:22 AM   #8
twojump36's Avatar
Go through the options and change it up.... Ours was that way from the dealer. I changed it first thing
2015 FR3 30 DS
1995 Wrangler
Miles 4600
Days Camped 48
twojump36 is offline   Reply With Quote
Old 04-24-2016, 01:48 PM   #9
A reverse image camera is just that. The picture you see in the monitor is exactly the picture your would see in your rear view mirror. You are facing forward, the camera is facing rearward. The Reverse notice you see on your monitor is just a warning that the picture is reversed (as it should be). You may be getting this because you recently installed the battery.
If you placed the camera in the windshield left would be right and right would be left. You would then need a front/forward imaging camera. Some cameras have a switch to change from one to the other.
PenJoe is offline   Reply With Quote
Old 04-24-2016, 03:26 PM   #10
It's in the settings go to menu to fix it.
Myrle is offline   Reply With Quote
