Old 03-01-2017, 07:32 PM   #1
Rookie error or fault??
I'm pleased to have taken delivery of a FR3 32DS yesterday , our first motorhome.
Alas there were a few issues spotted on the walk-around, & more became evident by the time I got home (park brake not releasing fully, door not closing, faulty armrest, hole in shade...). The coach will obviously be heading back for rectification, hopefully soon...
However there is one other issue that may just be my lack of understanding. The TV's and microwave don't seem to have power to them (they worked while connected to the external power at the dealers). I have checked the breakers in the bedroom, & even reset the GFI in the bathroom. Is there something I'm missing, or is this another fault?
While I'm at it, anyone know where the switch is for the map lights above the front bunk area?
Looking forward to the learning experience & getting these niggles behind us..
Thanks in advance for any advice.
ChrisEdwardsUSA is offline   Reply With Quote
Old 03-01-2017, 07:35 PM   #2
david_reaves's Avatar
Chris,
The TVs, Microwave, and any other 120 volt appliances ONLY work when connected externally (unless they are special 12-volt systems)
david_reaves is offline   Reply With Quote
Old 03-01-2017, 07:50 PM   #3
Thanks for the reply David, I guess that explains it. I had expected that they would be powered by the batteries when not connected externally, I'm sure the salesman mentioned that the TV's could be watched by passengers whilst traveling?
Old 03-01-2017, 08:01 PM   #4
ManlyMan's Avatar
If you run your onboard generator you will be able to watch television and run your microwave. This should have been explained to you.
ManlyMan is offline   Reply With Quote
Old 03-01-2017, 08:01 PM   #5
Who Dares, Wins
doc73's Avatar
Maybe, if you are running the generator or have an invertor (not sure but doubt the FR3 has it). I know with a Sunseeker the TV would not work because they disable it when the RV is in drive. But that can be disconnected pretty easy if the case.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 03-01-2017, 08:09 PM   #6
wmtire's Avatar
As a new RV owner, I usually recommend these articles that explain the electric systems in easy terms and also the SWDE Suburban water heater (if equipped)
These are a few things that some (not all) dealers don't really go over in much detail.
You can just peruse them at your leisure:
Basic RV Electricity - RV Information (RV Maintenance)
RV Converters and Amp Draw - RV Information (RV Maintenance)
RV Electric
Suburban's electric switch and much more
2011 Flagstaff 831 RLBSS
Geaux Tigers!!!!
Old 03-01-2017, 09:20 PM   #7
Antone's Avatar
You can run your generator while driving too and everything will work.
Antone is offline   Reply With Quote
Old 03-01-2017, 09:33 PM   #8
Jack Larson's Avatar
The water heater posts sure helped me as a new owner. It's hard to take it all in during the PDI. Many answers can be found here thanks to those who take the time to help us out.
Jack Larson is offline   Reply With Quote
Old 03-02-2017, 03:25 PM   #9
Royston's Avatar
If it is on the drivers side check the instrument light dimmer. beside the light switch I have a ford chassis and that's how I turn the map light on. Rotate past the point where the instrument lights are the brightest and it should click on
Royston is offline   Reply With Quote
Old 03-02-2017, 07:01 PM   #10
Thanks Royston, that solved the mystery of the map lights!
Still can't figure out the TV's / Microwave, not working even with generator running. Back to the dealers tomorrow...
Old 03-02-2017, 07:09 PM   #11
Antone's Avatar
Just to be sure, you do have it plugged in to the main in the left rear, correct? When you unplug from shore power, you should plug it back in. Otherwise the generator is not sending power anywhere.
Old 03-02-2017, 07:09 PM   #12
We had an issue with the emergency brake also. I believe ford had a recall on them. We had to take ours back to the dealer also.
Rdifuccia is offline   Reply With Quote
Old 03-02-2017, 07:46 PM   #13
Royston's Avatar
Can you try on mains power by plugging into a good power supply. If the fridge and M/W work then you may want to check the breaker on the generator, there are 2
Old 03-02-2017, 07:51 PM   #14
Dont forget to use the generator you need to plug the shore power (30 or 50 amp plug) into the "outlet" in the rear compartment. The outlet should be mounted in the last storage compartment on the drivers side and if I remember correctly is mounted on the wall that is the back wall of your coach. That connects you generator to the coach. Hope that's your problem and I can save you a trip.
Old 03-02-2017, 08:07 PM   #15
wmtire's Avatar
What the members above are trying to explain, that if your RV isn't equipped with an automatic transfer switch (which automatically switches your incoming power source from either the campground pedestal or the onboard generator), then you have to MANUALLY plug your power cord into the generators outlet. This way the generator sends power thru the shore power cord to your RV outlets and such.
If you unplug the shore power cord from the onboard generator outlet, and plug it into a campground pedestal....then the pedestal is sending power to your RV. You cannot plug into the pedestal outlet and the generator outlet at the same time. It's one or the other...and you make the choice,....but you have to manually do it.
If you are not plugged into the campground pedestal,,,,you have no AC power unless you manually plug the power cord into the onboard generators outlet.
See pic. Different RV's do this different ways. Some you plug into a generators female outlet like this pic. I don't have a pic handy of all the connection scenarios, but you should get the premise.
Geaux Tigers!!!!
Old 03-02-2017, 09:09 PM   #16
Antone's Avatar
Right, right. Thank you.
Old 03-04-2017, 07:56 AM   #17
Thanks for the tips everyone. The power cable was plugged into the generator receptacle, BUT I learned that to reset the GFI it has to have power to it at that moment. I had thought I reset it a couple of times, but not while the generator was running. Lesson learned! Thanks again everyone for taking the time to help.
Old 03-04-2017, 08:00 AM   #18
Royston's Avatar
We all learn something new every day on this forum, knowledge is not knowledge until you share it with someone
Old 03-04-2017, 10:07 AM   #19
Antone's Avatar
Old 03-04-2017, 10:18 AM   #20
BandJCarm's Avatar
Ha.
I had a college professor who said "Knowledge quadruples every time you share it with someone".
Took me a while to figure that one out, but it is (potentially) true! When both share again, it has quadrupled.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
roo
