08-24-2017, 07:02 AM
Running Fridge on propane on trip
2016 FR FR3 30DS
Might be a silly question, but on my first LONG upcoming trip, if you are running the Fridge on propane, do you just shut off the fridge when gassing the RV? Not sure if you need to turn off the propane tank when gassing.
Thanks for your answers..
08-24-2017, 07:10 AM
Many motorhome type rigs are equipped so that it puts the propane refrigerator in lockout for 15 minutes after the key is off to allow fueling. Is yours that way? Here's a page from a Dometic manual. Notice the red highlighted area...
08-24-2017, 07:13 AM
The official answer is yes. You are supposed to crank down the LP tank knob in the LP storage bin to stop the flow of propane to all devices.
The rational is that there are pilot lit flames in the fridge and hot water heaters. Those small flames are located inside covered areas and on the opposite side of where I fuel.
I personally don't.
If my fuel inlet were closer to an LP source I might follow the conventional wisdom.
08-24-2017, 07:19 AM
Do they even use Pilot Lights in these anymore ??? I know the oven does, but my 2007 and 2018 trailers didn't have any pilot lights for water heater or frig or furnace, they were both electronic ignition and didn't rely on pilot lights.
08-24-2017, 07:23 AM
Some refrigerators (mostly in PUP's/Truck Campers/A Frames) still have a constant flame. Everything else uses DSI. (Direct Spark Ignition)
08-24-2017, 07:31 AM
5 picker may be right. The newer hot water heaters may use a solenoid to open a gate and an electric infighter to start and a sensor to shut down if the infighter does not work.
My 30ds has a safety solenoid at the tank that is always on (powered) unless the the LP detector goes off.
It's possible that you might be able to use the master D.C. switch inside the door to shut off the safety solenoid. But I suspect it's wired to always be powered.
08-24-2017, 12:45 PM
ropane Usage While Fueling
I never run my water heater while traveling. It heats up quickly, so no need. Instead of turning off propane at the tank(s), I would think it easier and as safe to simply turn off the refrigerator while fueling.
08-24-2017, 02:16 PM
I personally don't.
OK, I understand your thoughts, I used to think the same way. Then went to a class on hazmat and changed my mind. Reason? Unless you are on the outside pump, and the wind is blowing, another vehicle could pull in and spill some fuel (from a burp in the filling process or whatever) and your reefer or waterheater sparks, Great Balls of Fire!!
We run from Nashville to Pensacola often and have no problem with food getting too warm, if its cold to start with, it'll still be cold when we get there. Turn your reefer and H2o thank off and enjoy the ride. Just my two cents worth!
08-24-2017, 03:02 PM
Never have, but make sure all electric shut off when filling propane
08-24-2017, 06:34 PM
A) Turn off the propane at the tank.
B) Turn off the fridge, or it will attempt to ignite...with the spark igniter firing steadily.
C) A safety interlock is not the same as being safe. Relying on any backup safety device as the primary safety device will work just fine -- until it doesn't.
An underground fuel tank full of gasoline may not ignite, but, lets assume something simple. You or a vehicle at a neighboring pump has the pump handle locked on, and you're relying on the pump to kick off when the tank is full. THAT device fails and there is a 5 gallon gasoline spill before you shut off the pump.
The fumes from 5 gallons of fresh gas on the ground will be extremely combustible. People are warned to ground themselves prior to touching anything around the pump if they have gone into their cars in cold (dry) weather for shelter. Static discharge from sliding out of your car seat can ignite the fumes around the filler neck and create a tragic situation. People are similarly warned to stay off cell phones near pump islands because there is a risk of a static discharge.
Now assume you started the fill-up and ran into the convenience store for drinks and snacks. Your family is waiting in the tow vehicle. There's a line...and you need to pee. The pump overflows. The automatic lockout on the fridge igniter times out at 15 minutes and the fridge igniter starts firing.
Turning off the propane valve and power to the fridge is something you'd have to do, at most, once a day (how many miles and fill-ups can you manage in a day?). It's worth the trouble to protect your family, others at the pump islands, and the investment in your rig. And in most jurisdictions, it's the law.
Jim & Renee
2020 Jayco Jay Feather X-213
Every weekend boondocking in the National Forests or at Lake Vallecito.
08-24-2017, 07:30 PM
Our tow vehicle runs on diesel and refuels on the left side of truck, our fridge is located on the right side of fiver about 25 feet to the rear of tow vehicle inlet to fuel tank. We have the electronic ignition and no open flame pilot light. If the red hot converter on my exhaust does not set off the diesel fumes, I am not too much worried about that fridge flame.
08-25-2017, 02:40 AM
The only propane appliance that is on while we aer traveling is the refrigerator. We seldom buy diesel when hooked to the camper but since the refrigerator is about 30' behind the fuel caps on our truck we do not bother to turn the reefer off. Diesel is not nearly as hazardous as gasoline in this regard either.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
08-25-2017, 10:10 AM
Makes sense if you're at a diesel-only pump island. Most in CO are shared with gas. Your "neighbor" at the pump could have a spill, be filling gas cans (which allows a lot of vapor), filling ATV tanks or a toy-hauler refueling tank or generator tank. A motorcyclist could overflow his fuel tank (no "self-respecting" biker would do this...until s/he does). There are many scenarios where fuel vapor could create an explosion hazard that has nothing to do with you or your vehicle - except for the possibility that shutting off power to your truck, triggers a safety interlock to turn off the fridge for a timed period, and before you leave, it tries to fire up again. A diesel with a large tank, auxiliary tank, or bed tank can take a long time to fill.
It's a stretch, but you needn't look far for evidence of pump island fires...even ones caused by vehicles crashing into the pump.
Jim & Renee
08-25-2017, 10:14 AM
And I could get hit in the head by a meteorite, maybe I should always wear a hard hat.......
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
08-25-2017, 10:21 AM
Or a tin foil hat!
08-27-2017, 06:52 AM
Houseboat fill ups
At Lake Powell, when we go to fill our houseboat, they require that the propane be shut off 10 minutes prior to gassing up. They also require all electric circuit breakers to be turned off, and all windows closed. We shut of the propane at the tank, light the stove to burn up the considerable gas in the lines, and then go in to get gas. They have learned this from experience. It has been two years since they had a houseboat fire at the dock.
I spotted something funny at the lake a few years ago. It looked like two long black parallel logs in the water. On closer inspection, it was all that was left of a houseboat. It had burned to the waterline. Even the aluminum was gone above the water line. I asked a Park Ranger about it, and he said they were filling their jet ski with gas from their house boat, and the fumes hit the gas water heater. They were all able to get off the boat alive, but I'm sure it was scary.
I turn off everything before I gas up the toys now. Gasoline has a narrow explosive range (1.2% to 7.6%). The mix of oxygen and gas has to be just right, but when it is, any little spark will ignite it.
