Old 03-18-2017, 12:45 PM   #1
RV keyless door lock
I just tried installing an RVlock Keyless Class C/A entry handle on my FR3 30DS. The two large latch bolts on the new handle are too short and the old bolts have a different thread. Has anyone else tried to install this handle, and how did they resolve the bolt problem.
Jim Carter
2016 FR3 30DS
jimcarterhb1951 is offline   Reply With Quote
Old 03-19-2017, 03:33 AM   #2
We have one ready to install but haven't looked at it yet. .. will be following
colourful64 is offline   Reply With Quote
Old 03-19-2017, 06:07 AM   #3
What length and thread size do you need? Have you tried a hardware store? RV doors can vary by only a small amount on thickness,did you call RV Lock and ask about your bolts? Youroo!!
Old 03-19-2017, 11:33 AM   #4
The bolts I am talking about are not just regular bolts, they are the two large bolts that protrude from the lock and go into the latch plate on the left side of the door. Nothing you would find at a hardware store.
Jim Carter
2016 FR3 30DS
Old 03-19-2017, 11:41 AM   #5
Hope you have better luck than I did. Does your handle have 2 large bolts that go into the latch on the left side when closed? Those bolts when screwed all the way in as they should be, are too short, and will not allow the door to close.
Jim Carter
2016 FR3 30DS
Old 03-19-2017, 11:50 AM   #6
And yes I called rv lock in Utah, it was Friday at 1:30 pm and I got an answering machine saying it was after hours. I will try again tomorrow.
Jim Carter
2016 FR3 30DS
Old 03-19-2017, 12:16 PM   #7
any chance you can take a picture of what you are talking about and post?
Retired USAF
2018 FR3 29DS
Calls Space Coast of Florida home...but Roll Tide
bamagrad1992 is offline   Reply With Quote
Old 03-19-2017, 01:05 PM   #8
RV lock
Motorhome is back in storage, so I only have pics of the new lock. The 2 bolts that are too short are below the deadbolt and above and below the latch.
ID:	132191   Click image for larger version
Jim Carter
2016 FR3 30DS
Old 03-19-2017, 01:20 PM   #9
I had the same problem with mine. Company told me to get an Allen wrench and back them out a little ways. I did so but I also applied some Loctite to them when I put them back in. Has worked like a charm ever since.
cmalberto is offline   Reply With Quote
Old 03-19-2017, 01:26 PM   #10
Thanks I was concerned about using Loctite semi-permanent might back out and permanent would be a problem as things shift and wear on the door. Did you use semi perm Loctite?
Jim Carter
2016 FR3 30DS
door, lock
