Originally Posted by 2happycampers2
The light is steady green and the beep is steady. If I turn the batteries off the light goes off but the peep keeps on going. When I turn the batteries back on the light blinks for a while and then becomes steady.
We're taking it to the dealer tomorrow morning. Hopefully they can figure it out.
Check your 'smoke detector' batteries. ( usually it's located on the ceiling)
When the propane detector goes off, the light turns red and the 'beep' is ear piercing. If the unit is 'off' and the light goes off, it's not going to give off an ear piercing 'beep'. Think about it.... no power, no beep. In fact, there's no way that I'd describe the sound as a 'beep'
Just like in a home smoke detector, the smoke detector in your rig has batteries that 'beep' when the batteries are low. While the beep is annoying, it's not going to cause you to jump and leave the rig to get away from the noise of the alarm. A 9V battery usually solves that problem.
