Old 06-18-2016, 12:03 PM   #1
Safe-T-Plus stabilizer
We have a 2016 FR3 28DS and want to get a Safe-T-Plus stabilizer. The mounting hardware comes in two sizes based on the tie rod size. Anyone know what size tie rod comes on this year of FR3? I emailed Forest River but no response to date. Thank you for any help you provide.
Name:	ImageUploadedByForest River Forums1466269402.640685.jpg
drewandjason is offline   Reply With Quote
Old 06-18-2016, 01:57 PM   #2
HAPPY WHEN RV'ING
drivmsafe's Avatar
Attachment 111467
You'll want the 41-180 stabilizer and the F-119K2.5 mounting kit.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 06-18-2016, 06:25 PM   #3
Great thank you.
Old 06-18-2016, 11:21 PM   #4
I just installed mine on my 32ds. Very easy install, takes 30 minutes. Call safety plus direct, that is what I did and they told me exactly what I needed. Just call them save yourself the aggravation they were more then willing to help me.
Only difference is, I ditched the lock nuts in favor of lock tight. On my back under the Rv without air equipment was to difficult. I used standard nuts, lock tight and torqued to specs. I had it checked by mechanic and he said as good if not better. But you must use lock tight if not using lock nuts. The pivot point is a side to side vibration which can cause loosening.
Also i used the standard nuts on the steering assembly which were
Lock nuts and standards (this is where you fine tune the steering after install), there is 4 of those, the big ubolt nuts is what I changed and ditched the locknuts.
I did this at first because my shipped unit was missing a nut. Ace hardware did not have a replacement and no time to wait. Once I started installing and used the lock nuts, they were to tough to tighten down even with a breaker bar. I found my solution to be much better and much easier. Also I used the blue lock tight, not the hard core red stuff. 4K miles
Later everything is still good.
linchat is offline   Reply With Quote
