Old 08-22-2015, 01:07 PM   #31
leisurelarry's Avatar
They took mine off to do the alignment and then reset it.
leisurelarry is offline   Reply With Quote
Old 08-22-2015, 01:21 PM   #32
@Photomaster, did they install some caster shims when they did your alignment? Seems like it helped quite a bit in keeping it tracking straight. Had 2 degree shim installed on the left, and 2.5 degree in the right. About $40 for the shims. First time I took it in, they didn't do anything with the caster. This time, I insisted they get the caster above 6 degrees to help it track straight and not wander.
KansasFR3 is offline   Reply With Quote
Old 08-22-2015, 01:40 PM   #33
No they did not. My total toe in was so far off it was ridiculous. Blew through my first set of front Goodyears. Had them replaced with Michelin motor home tires. I installed Koni's front and back. Coach drives, steers and rides so very nice now.
Old 08-22-2015, 01:42 PM   #34
Do you happen know the size or part number for the koni's?
patanke is offline   Reply With Quote
Old 08-22-2015, 02:10 PM   #35
For 2014 f53 chassis: Koni FSD front shocks 8805-1018, rear 8805-1019. Bought mine from Shockwarehouse.com. Best price and free shipping.
Old 08-22-2015, 03:49 PM   #36
Thank you!
Old 08-22-2015, 04:25 PM   #37
Your very welcome.
Old 08-23-2015, 09:18 AM   #38
Motoring
grotto69's Avatar
Picked up FR3 Yesterday with new safety plus installed. amazing difference. i can drive with one hand now. heck, I can drive with just three fingers on the wheel. should be standard for the coach
a little pull to the right though. just need to make a slight adjustment
grotto69 is offline   Reply With Quote
Old 08-24-2015, 01:45 PM   #39
PhotoMaster's Avatar
I'm not sure if they have to take it off or not.
Greg, Barbara and Cody the wonder-pup.
2014 FR3 30DS
(and 2 200cc Scooters)
PhotoMaster is offline   Reply With Quote
