Old 02-20-2018, 09:22 AM   #11
edm
The wires from the cable box in the right front compartment was run up through the floor into the front coat closet. the wire was run up the back side of the closet were all the other wires are at. then into the top shelf above the coat closet. The top shelf is were the direct tv receiver was installed. then I drilled about a 1 1/2 inch hole into the cabinet behind the tv box to wire in the tv. The power for the receiver was taken from the plug that services the tv.
our tv is directly across from the couch over the sink. The pictures aren't very good to show the hole I drilled.
Hope this helps.
edm is offline   Reply With Quote
lite, satellite
