Originally Posted by Brewster McFrisk
All you have to do is disconnect the house cable to the white amplifier by the door as you come in and add a coupling, then connect it to your Sat receiver. Plug your portable sat dish to the same place you would hook up your Park cable. I use my portable sat system everywhere we go.
Brewster
Thank you. That was a very clear and reassuring explanation of how to use a portable.
Do you have any recommendation for how to wire a roof mounted system? I don't want a long cable running to the rear of the coach to the "park cable" connector. I know the roof mount might present problems if I have to park under trees, but still want to know if it is possible.
Thanks for your help
