Hi there! I have a 2017 30DS, and I had the same issue with DISH and the mobile antenna, after several attempts at dealers, and Best Buy. I decided to consult with a cable GURU who told me that either Forest River has to wire separate wires for the receivers who actually produce the power to the mobile antenna. My DISH antenna is a Pathway 2X and has two ports, Main & alternate, I went ahead and drilled a hole under the bedroom, by where the electric and inverter is located. Found a way up through the back of the drawers and up to the TV hooking the first receiver, then I did the same in the front by the first door which houses the batteries. Up and through the back of the small closet by the stairs, and up to the TV and second receiver. This means I run two cables when the satellite is up, but I get both TVs with cable, and each room can see separate channels.
