Old 01-14-2019, 12:29 PM   #1
robo44's Avatar
Screen Door Cross Bar Handle Not Wide Enough
Anyone out there have a similar experience that I have with my Screen Door Cross Bar Handle I purchased.
I made the mistake of purchasing a Camco Silver Push Bar that extends from 21 1/4" to 28 5/8" in length. (Seems all the versions are the same "length". I thought (stupid me) that the screen door was "standard" width. NOT
However my screen door on my FR3 33DS is wider by 2 inches. I cannot mount this "standard" unit on my screen door. When extended as far as possible the mountain brackets do not reach any mountable area.
I need one that extends at least 30"
Anyone have a solution? Another Company/Brand or item that can be used?
2019 FR3 33DS Motorhome
Travels California Coast & Beyond
robo44 is online now   Reply With Quote
Old 01-14-2019, 12:37 PM   #2
Seems most of the universal ones that "fit most doors" are up to 28" and some change. Camco does make wider ones but a Google search shows there are other brands.
Example:
https://www.etrailer.com/RV-Doors/Camco/CAM43971.html
2017 Avenger ATI 26BBS
2012 Chevrolet Surburban
jayrodoh is offline   Reply With Quote
Old 01-14-2019, 12:57 PM   #3
robo44's Avatar
That is great! Thank you this helps!
Old 01-14-2019, 08:52 PM   #4
rk06382's Avatar
I installed Amazon: Camco Screen Door Cross Bar Handle - Allows For Easier Exit And Protection RV Screen Doors with Sturdy and Secure Grip - Wider Width (White) (42189) on my FR3 door. Works great.
Robert
2018 FR3 28DS
Samlex EVO-3012 Inverter/Charger| 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads |
Solar Power & Battle Born batteries thread
rk06382 is offline   Reply With Quote
Old 01-15-2019, 10:02 AM   #5
yes, i also bought a 'universal' one that was too short.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 01-16-2019, 12:16 AM   #6
New to FR. Old to TT
we have a 2019CC 36rl2 that has a wider door than std. and I bought that same handle but did not like the three bars so I bought the Camco screen door handle, shaped some hardwood pieces to fit tightly inside the open end of the tube and left a little out of the tube to fit in the handle then screwed the wood in the tube and into the handle. Works great and is very strong .
2018 GMC 2500 Denali HD ,Duramax with Allison trans.
2019 Cedar Creek 36ck2
Tall frog is offline   Reply With Quote
Old 01-16-2019, 09:19 AM   #7
Jesse's Avatar
Door Handle Solution
Two attached pics worked well for us. Sand down sharp edges pre-drill holes, works great.
Name:	rv screen door fix handle.jpg
ID:	194715   Click image for larger version
Name:	rv screen door fix handle2.jpg
Jesse
2016 F450
2017 Cedar Creek 38EL Champagne
Only here once - do it baby!
Jesse is offline   Reply With Quote
Old 01-16-2019, 10:51 AM   #8
Fifth Wheelers's Avatar
Jesse Thanks for the solution, I have a Champagne also.
2016 Champagne EL38
2016 Dodge Ram 3500 DWD
Fifth Wheelers is offline   Reply With Quote
Old 01-24-2019, 10:18 AM   #9
Add a filler
Add a small piece of metal to the back side of the door and install to it.
Iankerr is offline   Reply With Quote
Old 01-24-2019, 10:22 AM   #10
koller1509's Avatar
I did the same thing with my Sandpiper
Larry
2014 Ram 3500 Dually 4x4 6.7 Cummins
2017 Sandpiper 378FB
koller1509 is offline   Reply With Quote
door
