Old 06-22-2014, 08:56 AM   #1
screen for back window?
Does anyone have an idea for a screen for the back window in the FR3 30DS? I don't want something permanent as it still needs to be my escape exit. But, I'd like to be able to open the window and not have kitties get out or bugs get in.
Barbara
2014 FR3 30 DS
BarbaraG is offline   Reply With Quote
Old 06-22-2014, 09:10 AM   #2
Ford Idaho's Avatar
Could you post a picture of the window?
Old 06-22-2014, 09:31 AM   #3
Here it is. Using a dowl to keep it open. Thought of getting some screening and Velcro, but don't see any way to attach the Velcro without getting in the way of the shade or the window release mechanisms.
Any thoughts?
Barbara
Old 06-22-2014, 10:03 AM   #4
Ford Idaho's Avatar
Humm!?!?!?
In order to keep the kitty in you would most likely need to go clear around the window frame with Velcro unless the screening is framed, IMHO that would look terrible.
If the screening is framed it might be too thick for the shade to work as needed.
If possible would a Fantastic Fan or a Maxxair fan in the roof vent give you enough air flow?
Old 06-22-2014, 10:06 AM   #5
Yeah, you see the problem. I hadn't thought of a fan for the vent. I'll look into it. Thanks.
B
Old 06-22-2014, 10:27 AM   #6
Ford Idaho's Avatar
I know the fan is more money but in order to keep kitty in and let fresh air in or out with a nice looking finish the vent fan may be better option.
You really should wait as someone may have a better suggestion that may be less money.
Is that the only window in the general area?
Old 06-22-2014, 11:35 AM   #7
NELA
Weezer's Avatar
DIY Summer Door Window Flyscreen Fly Screen Wire Mesh Net Mesh Adjustable | eBay
What about this? The screen itself clings to *one* side of hook/loop type tape. That tape could easily be applied behind the levers for opening the emergency window. Simply pull off the screen when not in use and roll it up.
And, You could probably get the tape in a dark color that wouldn't be so visible on the frame of the window.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 06-22-2014, 02:47 PM   #8
Ford Idaho, There are two small windows on either side of the bed, but they don't provide much cross-breeze to the RV as a whole.
Weezer, That DYI flyscreen is much like what I've been thinking about. Think I'll investigate further.
Thanks.
Barbara
Old 06-22-2014, 03:05 PM   #9
Installed a Fantastic Fan last night using power off one of the lights. Works great and moves a ton of air. Took about 2 hours start to finish. best part is even without a breeze it ventilates.
/no kitty escapes from the FR3 Supermax
zippyzrx is offline   Reply With Quote
Old 06-22-2014, 11:39 PM   #10
Rfyler's Avatar
We had 3 Fantastic fans installed. Each replacing the existing vent. Air movement is no problem for these great fans.
Rfyler is offline   Reply With Quote
Old 06-23-2014, 11:32 AM   #11
Motoring
grotto69's Avatar
I saw temporary blinds at Home Depot they come in blackout and regular
grotto69 is offline   Reply With Quote
Old 06-26-2014, 08:04 AM   #12
Well, I tried a do-it-myself solution with screening and Velcro tape (had to take off the shade). All was going well until the second night when I realized I had hundreds of no-seeums flying around the light in the bedroom! Turns out the screening did not stay stuck to the adhesive on the Velcro very well.
Back to the drawing board...
B
Old 02-09-2015, 11:24 AM   #13
Technorick's Avatar
Barbara.
A winter project. We like air flow in the bedroom at night. And wanted to prop open the rear window of the 30DS at night without getting eaten by bugs.
I added a retractable window screen from www.qualitywindowscreen.com/store/retractable.
Name:	ImageUploadedByForest River Forums1423498549.656618.jpg
The product installation requires a one and a half inch existing wooden frame to mount the roller assembly and side slide guides to. I purchased the reverse model in bronze. That allows for space behind and between the screen allowing the pleated shade to stay in place.
This install required i build a wooden frame about an inch wider than the window on each side. I installed the retractable shade in the frame, removed the valance, installed the frame on the wall around the window with right angle clips, and replaced the valance to the frame.
2014 FR330 DS
Technorick is offline   Reply With Quote
