Old 11-05-2017, 06:04 PM   #21
Mountainmanbob's Avatar
Important and screws that get loose we put a small amount of epoxy on and screw them back in. Never (usually) a problem again.
Over the years in different units probably done this with 30 to 40 loose screws.
Curtin rods, doors, drawers, etc etc.
M-Bob
Mountainmanbob is offline   Reply With Quote
Old 11-05-2017, 07:40 PM   #22
M-Bob
With the epoxy can you get the screw back out if you ever need to?
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
Old 11-05-2017, 08:05 PM   #23
remove broken screw
Originally Posted by Bnrc73 View Post
One diy would be to use a Dremel and put a groove in the broken screws so they can be removed with a flat head screwdriver.
Ditto: This is the way I would try to remove broken screws.
twdenman is offline   Reply With Quote
Old 11-05-2017, 08:08 PM   #24
Yes, quick twist and breaks loose.
Try it and I think you will be very pleased.
Do a test screw -- remove it next day.
Some of those holes on our trailer stripped right out -- little epoxy -- still holding.
Lock Tight or JB Weld -- like fast setting.
M-Bob
Old 11-05-2017, 08:46 PM   #25
CaptnJohn's Avatar
M-Bob
Lock Tite BLUE, NOT red
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 11-05-2017, 08:52 PM   #26
B and B's Avatar
Originally Posted by CaptnJohn View Post
There is more than 1 way. 1st Lowes or HD will have a bit that goes in the drill and will bite what is left to remove what is left. Some call it an Easy Out. Last resort is to drill them out. That may require tapping for a larger screw. Once removed go Fastenal and get enough stronger screws made in the US to replace all of them. Imported fasteners rarely have the same strength even with the same rating.
The guy is in Newfoundland Canada and American made items made not be available. However some good Canadian invented Robertson screws would work just fine.
Old 11-06-2017, 08:05 AM   #27
No no no
You are talking about Loctite that can be used on metal screws screwed into metal such as car engines I do believe.
I am talking about Loctite two-part epoxy which mixed together can be used on Metals glass would excetera excetera.
JB Weld quick dry two part epoxy
M-Bob
Old 11-06-2017, 01:48 PM   #28
WolfWhistle's Avatar
Screws didn't pull out they snapped off. I wonder about the ice... already mentioned. Flat head wood screws aren't the right screw for the job. I don't think where its screwed to, you can get to the backside.
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
Old 12-31-2017, 03:27 AM   #29
Originally Posted by MaybzNDave View Post
Thanks! We actually already left St. Johnís and are back in Corner Brook. It came in and then went back out with minimal fuss except for the damage to the floor. The broken screws and dislodged mount are the big concerns.
I am from stepehnville. Lol
colourful64 is offline   Reply With Quote
slide
