Old 11-05-2017, 08:43 AM   #1
MaybzNDave's Avatar
Screws fell apart and slide is now damaged
Hello friends. We are still in Newfie 10 weeks later and are planning on going back to mainland this week so of course the rig decides to act up. 2015 FR3 30DS.
On bringing in the living room slide we heard an awful cracking noise, promptly put it back out. The floor behind the driver side is now gauged a bit, but more concerning is the fact the screws fell apart when we went to inspect things from the outside.
Has this happened to anyone? Is it a common issue (only saw the poor soul with the ultra-lemon mention something like this before)? How did you resolve it? Click image for larger version
ID:	155787Click image for larger version
ID:	155788Click image for larger version
ID:	155789Click image for larger version
ID:	155790At Kent (similar to Home Depot in the states) trying to find matching screws. Huge part of the problem is some screws broke in their holes.
MaybzNDave is offline   Reply With Quote
Old 11-05-2017, 10:11 AM   #2
II have a similar problem I dont know if I should use plastic anchors
welder is offline   Reply With Quote
Old 11-05-2017, 10:15 AM   #3
MaybzNDave's Avatar
Were not even sure how to get the broken ones out. Five of the six are broken in the hole on one side, and the two on the other side also broke in their holes.
Old 11-05-2017, 11:24 AM   #4
bubbles's Avatar
Forest River engineering at the top of their game. Shine on Forest River engineering; shine on.
Old 11-05-2017, 12:00 PM   #5
Lets start with "Who is the Slide MFG" and what Model#/Type is it? Youroo!!
Old 11-05-2017, 12:06 PM   #6
Might be able to work 2 of those out with pliers and patience. That last one looks like it would need to use an ez-out or just drill it out. They probably loosened up over time and finally snapped off.
2017 Rockwood MiniLite 2506S
2019 GMC Sierra 6.2L
2017 Colorado D-Max pulling 2017 Tracker 175TXW
Days Camped in 2017: 71
Days Camped in 2018: 37
Days Camped in 2019: 15
bshort is offline   Reply With Quote
Old 11-05-2017, 12:17 PM   #7
In regards to the "Brackets/Screws" there are other locations in the slots and additional/New holes can be drilled! If that wall attachment point has Aluminum behind the outer skin then "Aluminum Rivet Nuts" can be used with flat head bolts instead of the Wood fastener look alike that F/R uses! Youroo!!
Old 11-05-2017, 12:24 PM   #8
CaptnJohn's Avatar
There is more than 1 way. 1st Lowes or HD will have a bit that goes in the drill and will bite what is left to remove what is left. Some call it an Easy Out. Last resort is to drill them out. That may require tapping for a larger screw. Once removed go Fastenal and get enough stronger screws made in the US to replace all of them. Imported fasteners rarely have the same strength even with the same rating.
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 11-05-2017, 12:37 PM   #9
One diy would be to use a Dremel and put a groove in the broken screws so they can be removed with a flat head screwdriver.
Bnrc73 is offline   Reply With Quote
Old 11-05-2017, 12:55 PM   #10
WolfWhistle's Avatar
I don't know how important it is to mount bracket to the exact placement. Here's a link to the typical screw extractor, however there is more than one way to 'skin a cat'.
https://www.amazon.com/dp/B01NGTLM40...a-318198613386
I would probably carefully grind broken screws to flush and drill new pilot holes... probably just above the existing ones.
I noticed and would like to point out the screws look like flat head (countersunk) wood screws and the holes / slots in the bracket are not countersunk. In my way of thinking this could cause this failure, especially if they were over-tightened.
I have to believe that a truss head screw such as made by Fastenal would work better.. search here... pick the length and size like your's... I'd replace the other side as well.
https://www.fastenal.com/products/wo...0Screws%22%7C~
WW
Hyper Lite was sold
2017 F-250 4x4 6.2L Gas
slide
