Old 08-01-2016, 07:58 AM   #21
Team Bleu
OK we found the problem, we actually removed the toilet, it is the valve up in the back connected with the handheld sprayer. It was so damn clogged, but with power pressure the little black rubber ring got displaced, so it now spraying water all over. So as I travel this week I'll stop at a Camper World and have them replace it. So the container of water will be filled for now. One thing we did have installed when they replaced the toilet was to have them add an on/off valve just incase I had water issues. Also bought an extra water filter to attach to hose when connected outside water systems
DBsRedVett is offline   Reply With Quote
Old 08-01-2016, 06:58 PM   #22
Retired Aerospace Engr.
Toilet water line cloded
I'm beginning to wonder how many people only use the low-point drains in draining their systems instead of removing the Water heater anode to drain it first. If the anode is removed first (after opening faucets to relieve water pressure), all the white crud from the deteriorating anode comes out the port where the anode is installed. Low-point drains should be used last.
If the low-point drains are used first, some of the white crud comes out into the cold water line where it waits to be run into the toilet valve and bath faucets. See comment above by "Flybob".
The anode is the ultimate problem, not water filtration on the city water inlet side. The manufactured system, when new, is absolutely clean; no FOD or other particles. If a filter is needed, it is in the water delivery line immediately prior to the toilet valve.
Bottom line - check and change the W/H anode regularly.
DUBLBZ is offline   Reply With Quote
Old 08-02-2016, 05:25 AM   #23
Wolverine 1945's Avatar
Very Good Point !!!
As I said I drain the W/H after every trip !!!
It maybe a waste of water,,, but I conserve in many other ways !!!
Wolverine 1945 is offline   Reply With Quote
faucet
