Old 06-06-2017, 10:12 AM   #1
Sewer pipe stowage
On my FR3 32DS I got 2 4" DWV pipe in the area over the propane tank. I zip tied them to the steel tubing on the underside of the floor. They are installed at about 15 degree slant so the sewer hose will not slip out. There are end caps on the lower end with 1" holes in the caps for any drainage needed. I use PRESS TO FIT sewer hose fittings because they are a smaller o.d. than most fittings & slip in the 4" pipe very easily.
I also used a LARGE zip tie to tie around the center of my sewer elbow to connect a carribiner clip which I clip to an eye bolt. This keeps all the sewer hose & fittings away from anything else.
I
Kentucky Bob is offline   Reply With Quote
Old 06-06-2017, 10:26 AM   #2
Prime Member
I stow mine in the hollow rear bumper.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 06-06-2017, 10:50 AM   #3
Good idea,
I thought of that also, but my 32DS doesn't have a hollow rear bumper.
Old 06-06-2017, 12:01 PM   #4
muddyrode's Avatar
No pictures? and not of the rear bumper
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 06-06-2017, 12:23 PM   #5
I store ine in the same place on my 25DS. I also have a second plastic fence post that holds a collapsable full size ladder.
KY25DS is offline   Reply With Quote
Old 06-06-2017, 12:40 PM   #6
Pictures of the sewer pipe storage
Trying to attach pictures, but having trouble. So here is another try
Old 06-07-2017, 09:00 AM   #7
Kadiddle's Avatar
Many solutions
There's been quite a few great solutions posted for sewer pipes in the FR3s. Here's mine inspired by some of those posts. I happened to go over the jack hydraulic system.
ID:	140395   Click image for larger version
2015 FR3 30DS
2010 Ford Escape Toad -or- 2012 Ford Focus Toad
Kadiddle is offline   Reply With Quote
Old 06-11-2017, 06:40 PM   #8
one of the best posts ever. have been looking for a place in my 29DS. now i have options! will probably do the 5" square fence post with cap. over the propane. thank you fellas!
b
Retired USAF
2018 FR3 29DS
Calls Space Coast of Florida home...but Roll Tide
bamagrad1992 is offline   Reply With Quote
Old 06-12-2017, 05:17 PM   #9
Kadiddle's Avatar
The ONLY reason I didn't put the pipes over the propane tanks is so that the propane filler person doesn't have to see/smell the pipes when filling. I also go in there for a 1"-20 grill hose attachment. Otherwise, it's a great location (at least in the 30DS).
2015 FR3 30DS
Old 06-12-2017, 07:47 PM   #10
so have built two 5x5" fence post w/cap. now looking to mount to the propane storage area. any recommendations on where to mount? zip tie both together then zip tie to the frame? or zip tie each individually to the frame? mounting will commence tomorrow as i ran out of daylight today...
love that i can get the slinkys out of a storage box and into the "air". and frees up storage space...
thanks forums!
b
Retired USAF
2018 FR3 29DS
