Old 06-06-2017, 10:33 AM   #1
Sewer pipe stowage
On my FR3 32DS I got 2 4" DWV pipe in the area over the propane tank. I zip tied them to the steel tubing on the underside of the floor. They are installed at about 15 degree slant so the sewer hose will not slip out. There are end caps on the lower end with 1" holes in the caps for any drainage needed. I use PRESS TO FIT sewer hose fittings because they are a smaller o.d. than most fittings & slip in the 4" pipe very easily.
I also used a LARGE zip tie to tie around the center of my sewer elbow to connect a carribiner clip which I clip to an eye bolt. This keeps all the sewer hose & fittings away from anything else.
I
Kentucky Bob is offline   Reply With Quote
