Old 10-27-2015, 11:11 AM   #1
DavidMPDK's Avatar
Shower Caulking. To do or not to do, that is the question?
Hello everyone. Just picked up my New 2016 FR3 30DS. Great unit. I noticed a gap in the shower between the floor pan and walls. Is this a miss or done by design? Should I caulk this area before it's used or does it not leak? Do I use normal bathtub sealant or leave it alone? Thanx in advance.
2016.5 FR3 30DS AKA "Serenity"
Searching for that perfect spot with loving Wife & 2 mini dachshunds
DavidMPDK is offline   Reply With Quote
Old 10-27-2015, 11:28 AM   #2
I dont have your unit, I have a TT but I have a tub and there was a gap between the tub and the wall surround. I caulked mine mainly because I have a 3 year old son that takes bathes and likes to splash. I wanted piece of mind just in case. I used regular shower caulk and it has worked fine for almost a year. Hope this helps.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 10-27-2015, 11:33 AM   #3
Gregg Willow's Avatar
I have a corner shower with a bottom pan. It looked like it could leak and did immediately when I tested spraying the walls. Of course, this was after PDI. I used a clear shower caulk and fixed the problem. I do not understand why they do not do this simple task.
2016 Ford F-150 4x4 Supercab XLT EcoBoost
2012 Salem Cruise Lite 221RBXL, Andersen No Sway WDH, (2) Honda EU2000i's
Gregg Willow is offline   Reply With Quote
Old 10-27-2015, 11:37 AM   #4
Retired guy
Big Dog 1's Avatar
I was told that gap was intentional to allow for draining and prevent mold and mildew from forming. I was advised to leave it alone.
Big Dog 1 is offline   Reply With Quote
Old 10-27-2015, 12:02 PM   #5
TURBS's Avatar
X2 the floor pan goes quite aways up behind.
Shower would have to overflow to get up and behind, and even then I don't think it would.
Old 10-28-2015, 02:22 PM   #6
You are right , there is a 1 1/2 " lip all the way around. Water will not get up there unless deliberately sprayed up into the area. The tub surround and base are designed to be able to move as the box of the RV flexes. I have seen how much movement there is in one. Back when I was at a training seminar and we set up a 35' fifth wheel with gauges in many arras of the unit. the gauge measured the movement and froze at the maximum movement. Unbelievable! I remember when we first put the tub surrounds in trailers. We had to replace most of them the first year. They glued and screwed them in place and they all cracked. That is what the step down area is for at the base of the shower wall.
hillsdaletc is offline   Reply With Quote
Old 10-28-2015, 02:40 PM   #7
MarsMan's Avatar
X2
MarsMan
2015 Coachmen Prism 24J MBS
USN-R '01-present
MarsMan is offline   Reply With Quote
Old 10-28-2015, 08:23 PM   #8
No lip on the base of the shower on my forest river. First shower I took the water ran out from under the shower.
fander is offline   Reply With Quote
Old 10-28-2015, 08:43 PM   #9
trbomax's Avatar
Since I am very paranoid about any water getting under or in any walls or flooring,I caulked the surround and shower base everywhere before it was ever used.I used non leveling white dicor. a year and 7000 miles later nothing is cracked or leaking.
trbomax is offline   Reply With Quote
Old 10-28-2015, 09:09 PM   #10
Dahagen
Turbs is right!
dahagen is offline   Reply With Quote
caulk, show, shower
