Old 05-11-2014, 10:31 AM   #21
StephanFR3's Avatar
Rivets were original not added.
Sent from my SAMSUNG-SM-G900A using Forest River Forums mobile app
StephanFR3 is offline   Reply With Quote
Old 05-24-2014, 02:47 PM   #22
Motoring
grotto69's Avatar
Mine arrived. I'm putting this in tomorrow. Any tips?
grotto69 is offline   Reply With Quote
Old 05-24-2014, 09:45 PM   #23
StephanFR3's Avatar
Remove the rubber door stop/ close fastener that is tiewraped to the top of the accordion before you install it. It is a bear to get it off after the door is installed.
Old 05-25-2014, 03:41 PM   #24
Motoring
grotto69's Avatar
Yup, got it. That is a little bugger that is hard to notice, almost looks like a tag hanging there or something.
Old 05-25-2014, 04:05 PM   #25
How did the install work out? I think Ill be buying one of these shortly if you guys say its good.
cucamelsmd15 is offline   Reply With Quote
Old 05-25-2014, 04:28 PM   #26
StephanFR3's Avatar
Hardest part is removing the white rivets in the shower wall.
Try using a tiny drill bit and then a small screw to pull the center part of the plastic rivets. Though I just pried them out with a door panel pry tool.
Old 05-25-2014, 05:26 PM   #27
Pick up a mini pick tool set and you can pull them out without drilling a hole.
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 05-26-2014, 03:11 PM   #28
Motoring
grotto69's Avatar
Yours may not have rivets, mine didn't. I completed the install today in a little more than an hour. You will need clear Silicone, if you get that before you begin, you'll save some time as you need it after you install the bottom rail.
The install is pretty easy, walk through one time before you peel and stick or cut anything and you may safe yourself some trouble.
As far as it working... I'm convinced it is not going to leak one drop. Any water that runs down the curtain drains back into the shower - you will seal up all those other seems when you're done.
The only con I found is it is tricky to slide. The instructions say to spray silicon on the aluminum track - that probably will help, I didn't have any to try it. Sliding it to closed, the hanging curtain at the top can get hung up on the track, since the bottom is not tracked it has momentum and rises up right on out of the track. You just have to put it back in. You just have to tell people "Go slow and be careful, I mean very slow"
For the price - it's worth it over the curtain simply because the curtain setup redirects any water that hits the walls directly into the coach.
Grotto
Old 05-26-2014, 06:37 PM   #29
Ordered. And I dont have the rivets so it should be pretty simple in my case.
Oh hell, last time I said "oh it should be pretty simple", I found myself knee deep in pulling a motor out of the car. Maybe I shouldnt say that again.
door, show, shower
