flip up tv in bedroom
I used ( think it was a 13 inch tv- you might use a 15 in depends on brand and how much border is on the edge of tv) I built my mount from plywood -painted it black- used a piano hinge from home depot, as well as a magnetic mount for bottom latch-they also had a silver handle to match hardware on front tv -- the shocks and brackets for them ordered from a supplier on line. Took a little figuring on measurements, but came out as good or better as the one in the living room. mounted a dvd player behind the now usable space and still have plenty of space for other things as well=even put me a small shelf in to make it even more versatile. Good Luck! Larry[QUOTsiE=glwolf;669595]Lfrazee: You mentioned mounting the bedroom TV to flip up like the main TV. Where did you get the mount, and what size TV did you use?
Thanks[/QUOTE]
