Old 08-15-2015, 11:50 PM   #1
Sirius Radio Antenna Install
Purchased the add-on tuner to make the dash radio get SiriusXM and it says it requires the antenna to be installed on the roof.
I have a 30DS. Does anyone have an easy way to access the roof to attach the antenna or have any experience with reception with the antenna placed in the interior.
Paul
JABuyer is offline   Reply With Quote
Old 08-16-2015, 09:30 AM   #2
I did the same install. I routed the wire from the radio, through the engine firewall to the right hand side of the frame. Then up through floor on the right hand side of the door. Then follow the LED/awning wiring up the awning rail to the roof. Then under the drip rail fwd, the mount the antenna on the front cap. Been working good so far. You'll have to buy 10 ft extension cable and splice into the factory antenna wire. Just cut the end off the factory antenna and route from the roof down. It'll get you to about the battery area. Then cut the correct end off the extension cable and route from the cabin through the bulkhead to the battery area. Soldering the XM cable is pretty delicate, but wasn't too hard. Just make sure to solder the overbraids together, and the inner conductor together, but keep them separate once you heatshrink everything together. Might not be the easiest, but its the way we did ours. Hope it helps.
I bought this extra cable.
http://www.amazon.com/dp/B00DMFAOA6/...xtension+cable
KansasFR3 is offline   Reply With Quote
Old 08-16-2015, 02:44 PM   #3
XM antenna
I just installed my portable magnetic antenna to the rail that the bunk bed comes down on. It doesn't move and I have not lost reception while on the road. I used the xm radio from my office so I did not have to go through the radio on my FR3. This works just as well without going through all of the wiring and cables.
progolfer is offline   Reply With Quote
Old 08-16-2015, 07:25 PM   #4
fpo1123's Avatar
I put antenna under the dashboard just stick it to the metal brace with the antenna close to the front. Haven't lost signal yet, except thick wooded areas, but I lose it in my car in the same places with a factory antenna.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
fpo1123 is offline   Reply With Quote
Old 08-17-2015, 12:25 PM   #5
Retired Ford Tech
Question
I installed a Sirius ant on my GT by going out the pass window, along the awning and siliconed a flat washer to the roof,
I also read an older post that someone mounted it in their overhead cabinets. Since the roof is fiberglass it still got a signal. If you haven't run the ant wire, give it a try.
rvpezzano is offline   Reply With Quote
Old 08-17-2015, 10:23 PM   #6
Retired guy
Big Dog 1's Avatar
How does the add on tuner connect to the radio? I thought these contraptions came with sattelite radio integrated into them and activation similar to starting up a new account like when you buy a new car that comes with a free subscription.
Big Dog 1 is offline   Reply With Quote
Old 09-13-2015, 03:59 PM   #7
Newbie
Question Aux input to radio on 30ds
Just bought a 30ds and haven't taken delivery yet, but the wife wants sirius like in her car. Does the radio have an aux input available on the front panel or in a convenient place to plug into so I don't have to re-cable...?
TIA.... Stefan
StefanG is offline   Reply With Quote
Old 09-13-2015, 04:33 PM   #8
Georgia Frog Rally 2018
aceinspp's Avatar
Most vehicle radios have the aux jack to plug in a Sirius /XM radio. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
aceinspp is online now   Reply With Quote
Old 09-13-2015, 07:43 PM   #9
fpo1123's Avatar
If you have a smart phone you can download the xm app and play off that. They do have a USB port on them I think. I changed my radio system all together awhile back so I don't remember.
MSG (Ret)
U.S. Army
Active-duty 66-92
2015 FR3 30DS
Old 09-13-2015, 07:57 PM   #10
Retired guy
Big Dog 1's Avatar
You need the SiriusXM SXV300 Connect Vehicle Tuner
Model #: SXV300V1 $69.99 with three months free service and $10.00 off if you are an existing customer and ask for it. Unless you know how to pull the unit out of the dash and set up the tuner and antenna I suggest you take it to a mobile stereo shop.
antenna, radio
