Old 09-06-2018, 06:55 PM   #1
Slide gearbox
A member (gomatthew) is sending me 2 broken gearboxes that I will be reworking and I will submit my new design changes to the manufacturer..
I will make a bracket with the double sprocket tied to ia separate shaft and then coupled to the motor shaft , so if the motor or gearbox ever needs replacing, it should be a 10 minute job. It is insane that it is set up so you need to loosen all the cables to change out the gearbox.
Bob
Kentucky Bob is offline   Reply With Quote
Old 09-08-2018, 07:25 AM   #2
Good Luck!
If they adopt the changes, I hope you get paid for them!
OldGunny
2016 FR3 30ds
OldGunny is offline   Reply With Quote
Old 09-08-2018, 01:19 PM   #3
I may be more interested in selling the adapter plate and supplying modified gearboxes
Old 09-09-2018, 01:20 AM   #4
Iím in if you complete!
lazbo is offline   Reply With Quote
Old 09-12-2018, 03:05 PM   #5
I received 2 old gearboxes today from member (gomatthew) to study changes needed.
I worked up the drawing for an adapter plate (about 4" X 7") to hold the sprocket in place.
If the gearbox ever goes bad, you will only need to loosen a set screw on a coupling that connects the sprocket shaft to the gearbox shaft.
Then slip the gearbox shaft out of the coupling. No need to loosen cables, chains etc.
A gearbox swap out should take less than 10-20 minutes. As long as you have removed the wood panel covering the motor / gearbox.
Since the gearboxes are supplied with sprockets, you would also need to remove the sprocket on the new gearbox.
Old 09-12-2018, 03:18 PM   #6
Iwannacamp's Avatar
American ingenuity at work.... Good for you!
2017 Puma 297RLSS
Iwannacamp is online now   Reply With Quote
Old 09-12-2018, 06:37 PM   #7
Awesome!
OldGunny
2016 FR3 30ds
Old 09-12-2018, 10:28 PM   #8
Great job....we all need that
Old 09-13-2018, 12:11 PM   #9
gomatthew's Avatar
Have any video?
gomatthew is offline   Reply With Quote
Old 09-13-2018, 02:29 PM   #10
No video or pictures yet. I will order parts tomorrow to make up the assembly.
slide
