Old 06-01-2017, 12:37 PM   #1
Slide hardware question
How do I send a picture to this site?
welder is offline   Reply With Quote
Old 06-01-2017, 01:00 PM   #2
CampingGator's Avatar
In the reply box, click on "go advanced ". Then, after you write what you want to say, click in the "manage attachments " area to upload area and select your photos. I believe it allows up to five. Occasionally I have problems with it, but it generally works and is easy.
_____________________________________________
2010 Ford F-150 Crew Cab
2015 Salem Hemisphere 263RL
CampingGator is offline   Reply With Quote
Old 06-01-2017, 03:17 PM   #3
Old 06-01-2017, 03:28 PM   #4
Looks like you figured it out... what are you trying to tell us?
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 06-01-2017, 04:02 PM   #5
There is a void where I removed the screw. I think I should use an anchor rather than a screw. Any comments.
Old 06-01-2017, 05:13 PM   #6
Old 06-01-2017, 05:52 PM   #7
Mr. Dan's Avatar
I changed the thread title from "Pictures" to "Slide hardware question" hoping more members will open the thread and respond.
Dan
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 74; booked = 12
Old 06-01-2017, 06:56 PM   #8
Old 06-02-2017, 07:33 AM   #9
Carl17's Avatar
screws
Same problem here. My screw broke in the slot area so I drill next to it and install a new screw next to it .
I would try to drill out old screw and replace or check and see if you could put a through bolt 5/16 or 1/4 in same place or next to it .
When drilling out get a left handed bit a good one .
Carl & Bette
2018 Leprechaun
NEW YORK
Carl17 is offline   Reply With Quote
Old 06-02-2017, 10:28 AM   #10
What do you mean by a through bolt. There is no way to get a nut on the bolt.
pictures
