Old 08-10-2018, 10:31 AM   #1
slide motor location
On a 2015 FR3 28DS, where are the slide motors located? Can't find any info in manual.
Chief1968 is offline   Reply With Quote
Old 08-10-2018, 10:44 AM   #2
DavidMPDK's Avatar
This might be too much info for now but I suggest you save it for when you need it. It's not if but when it will happen.
2016.5 FR3 30DS AKA "Serenity"
Searching for that perfect spot with loving Wife & 2 mini dachshunds
DavidMPDK is offline   Reply With Quote
Old 08-10-2018, 10:55 AM   #3
Lacey's Spring, AL
formerFR's Avatar
if you have the typical electric 'swintech' brand slides rails - then you probably will find them at the top of each slide end, within the wall.
are yours not working?
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx, 100,000+mi since '14... US, Alaska, and Canada... from W.C. Georgia, then W. North Carolina, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
Old 08-18-2018, 01:39 AM   #4
PhotoMaster's Avatar
I have a 2014 FR3 30DS and they are located above the slide out, behind the wooden trim. Major nightmare to get to. Even the dealer had to replace all the wooden trim because removing it damages the trim.
Greg, Barbara and Cody the wonder-pup.
2014 FR3 30DS
(and 2 200cc Scooters)
PhotoMaster is offline   Reply With Quote
cat, location, slide
