06-25-2017, 01:42 PM
Slide out motor location
My bedroom slide out will not retract. How and were is the motor located and how do you access it?
06-25-2017, 01:44 PM
Better tell what you have for RV and model #
Fonzie
06-25-2017, 01:45 PM
Sorry 2016 FR3 30DS BEDROOM. SLIDE
06-25-2017, 01:55 PM
I'll look again for proper info....it seems you have cables on outside of slide? yes or no? I thought these were rails....
Fonzie
06-25-2017, 02:00 PM
(null)
This is my unit bet my slide system slides using what looks like a large bicycle chain. None of the videos show my class A
06-25-2017, 02:06 PM
Cables
06-25-2017, 02:08 PM
If you look a time frame 3:50 does your slide have same cable system top and bottom?
Fonzie
06-25-2017, 02:15 PM
Yes sir I have cables top and bottom
06-25-2017, 02:17 PM
My manual say all I need is a power drill to close it. But I can not find the motor location.
OK, then I would say you have the Accuslide system...
https://www.youtube.com/results?search_query=accuslide
Fonzie
06-25-2017, 03:23 PM
Fonzie that did the trick, room retracted!!!! I surely appreciate your time and effort. I tried looking on line but not luck did not know the type of slide. Again thanks
06-25-2017, 03:42 PM
You're welcome...
Fonzie
06-26-2017, 07:38 AM
What was the problem and the fix for this
06-26-2017, 09:15 PM
Motor location is generally behind the upper trim (or if cabinets are over the slide then the false back of the cabinet) will reveal the motor. Motor will be in the center.
The trim has screws under the plugs.
06-26-2017, 09:17 PM
Thanks I located it and fixed the problem....
06-27-2017, 06:53 PM
what was the problem?
06-27-2017, 07:43 PM
Could not retracted the bedroom slide, I think I overextended it. After retracting a few inches I checked the switch and it closed the rest of the way on its own.
08-15-2017, 11:37 AM
For the bedroom was the motor behind false back of cabinets or trim?
2015 FR3 30DS
08-15-2017, 12:43 PM
The bedroom slide components are located behind this top trim piece. Remove 3 screws under plastic plugs and the trim falls right out.
08-15-2017, 07:32 PM
Be sure to check the slides movement in and out. If there is any slipping in the movement then the gearbox is going to fail at some point (may fail anyways...ymmv).
The next thing to look at is if cables are within the tension specification. This is checked both open and closed on the slide. If one side is loose it will open/close but it is going to gove you problems. The guide and videos show how to adjust. Ive had mine for 3 years now and adjusted twice (once by dealer under warranty and once now by myself after replacing both motors gearboxes.). The gear box is designed to be the weakest link so you dont break something hard and expensive to fix.
If anybody does lose just a motor ive got 2 extra that work fine.
