Old 08-28-2015, 04:00 PM   #1
Slide problem
The cables on the main slide are loose on one side. How big a job is it to adjust the cables?
welder is offline   Reply With Quote
Old 09-01-2015, 07:43 AM   #2
Technorick's Avatar
Do a search on YouTube for Accuslide troubleshooting. There are some excellent vids there on how to adjust and replace the cables.
2014 FR330 DS
Technorick is offline   Reply With Quote
Old 09-02-2015, 01:06 PM   #3
b1barnes's Avatar
Slide problem
The job is not bad. Adjusted the front slide as when it opened it was dragging the slide on the floor. Top cable was too loose.
Remove the top trim cover and move the slide until the adjuster couplers are accessible. Adjusted until slide movement in or out resulted in no tipping either forward or back. Repeated for both sides to be sure all was equal.
Added result was slide seems to move more freely and motor does not labor as much.
b1barnes is offline   Reply With Quote
slide
