Old 06-25-2018, 05:59 PM   #1
Slide Squeak
Living room slide squeaks behind drivers seat while driving on my FR3 30 DS. Any ideas other than turning up the radio. Thanks
Fr3 Frank is offline   Reply With Quote
Old 06-25-2018, 07:14 PM   #2
rk06382's Avatar
Maybe you should check the cable tension. It may not be closed on the drivers side.
Robert
2018 FR3 28DS
Samlex EVO-3012 Inverter/Charger| 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads |
Solar Power & Battle Born batteries thread
rk06382 is online now   Reply With Quote
Old 06-25-2018, 07:44 PM   #3
Thanks, cable tension seems to be good. Slide even with slide closed.
Old 06-25-2018, 07:54 PM   #4
Papaduck's Avatar
You might want to look for contact on the slide out rollers. They might need some dry silicone lubrication applied.
Chuck & Donna
U.S. Army - Retired
2016 FR3 30DS w/2016 Chevy Colorado Toad
Days Camped: 2017 - 45, 2018 - 52, 2019 - 65
Papaduck is offline   Reply With Quote
Old 06-26-2018, 06:38 AM   #5
Had the same problem, fixed it by putting aluminum shim plates under the slide out where the rollers ride. Started off only doing the outer edges but eventually did the inside ones too. I wrote about this within this FR3 forum.
Combatcoal is offline   Reply With Quote
Old 06-26-2018, 06:41 AM   #6
Careful that only makes it worse as you now have a more slippery surface ( coefficient of friction changed) for the plastic roller to move on. The whole slide is moving towards the driver and then towards the back. It needs to be shined.
Old 06-30-2018, 11:58 AM   #7
HortMi's Avatar
I had a similar noise. It was hard to find while driving. Anyway thought the noise was coming from the slide and found it was the bunk above the drivers seat that was a squeak at the latch.
HortMi is offline   Reply With Quote
Old 06-30-2018, 12:17 PM   #8
You might want to try experimenting with the slide cable tension. We had a squeak, which stopped when I relaxed the cable tension a little. I bring the slide all the way "In", and then press "Out" for a split second. The slide doesn't actually move outward, but the tension on the cables is decreased.
2016 FR3 30DS
Thousand Oaks, CA
RV Trip Photos
vacationlovers is offline   Reply With Quote
Old 06-30-2018, 04:07 PM   #9
Thanks....Lot of good suggestions. I will try this when I get a chance. I hope it is this easy.
Old 08-02-2018, 12:40 PM   #10
BINGO!! This worked for me. Thanks a lot.
slide
