Old 09-21-2018, 09:14 AM   #1
PeteAndEd's Avatar
Slideout Deterioration
My mechanic told me I should keep the underside of our slides clean to prevent any kind of stress on our slides going in and out. So... yesterday, I was cleaning the underside of the BR slide and noticed it has started to crack on 1 roller. It is only doing this on the BR slide and only on the 1 roller. To my untrained eye, it looks like too much weight is bearing down and something above it is separating.
I think it's too early to perform a warranty repair as the slide is still functioning.
Any suggestions?
FR3 2015 30DS
PeteAndEd is offline   Reply With Quote
Old 09-21-2018, 09:17 AM   #2
Looks broken. I would do the warranty now or very soon.
OKI Marine is offline   Reply With Quote
Old 09-21-2018, 09:40 AM   #3
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
I agree, don't wait.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 09-21-2018, 09:47 AM   #4
PeteAndEd's Avatar
My extended warranty on the slides has a $500 deductible... that's my hesitation at the moment. I'll take it into the RV mechanic and have him look at it... but thought I'd mention it here to see if others may have the same thing and any solutions/thoughts/etc.
Thanks for the replies so far!
FR3 2015 30DS
Old 09-21-2018, 10:31 AM   #5
This may not be good advice, so please take it FWIW .
You could go to a metal shop and have them cut 1/16" 10" wide galvanized steel plates, epoxy them under the slide floor and secure the edges with self tapping panhead screws (make sure the rollers can't make contact with the screws).
Old 09-21-2018, 10:46 AM   #6
If it is covered under warranty why the need to pay a deductible
Old 09-21-2018, 01:18 PM   #7
PeteAndEd's Avatar
Mfgr warranty is long gone (1 year I think). At the time of purchase, I purchased an extended warranty package which included the slides. Sorry, should have mentioned this in my original post. I've repaired both slide gear boxes at over $1,000 each with $500 deductibles each time.
FR3 2015 30DS
Old 09-21-2018, 01:33 PM   #8
Ouch ! Seems like rv manufacturers set themselves up with that 1 year warranty. Hardly any time for the owner to use the rig to catch problems before hand. I had a similar situation with my axles. Once Forest River admitted my 5th wheel should have had larger axles ....... I was past the warranty. Paid for new axles, freight and install myself.
Old 09-28-2018, 05:55 PM   #9
Have the same thing on my 2017 fr32. I called the factory rep for my area and he told me that they have a plate that is wider than the roller and that would go under the roller mine is going to be covered because I have had many things wrong with this unit.they have been very good taking care of the moterhome.I live in upstate New York
cameron4467 is offline   Reply With Quote
Old 09-28-2018, 06:42 PM   #10
PeteAndEd's Avatar
I just wish all of the "little" things that show up would should up prior to the end of the 1 year "bumper to bumper" RV warranty...
Is your plate just wider than 1 roller or both rollers on the BR slide? Do you know the plate thickness by chance?
FR3 2015 30DS
slide
