Originally Posted by JohnCD
Thank you for your reply...great information and very thorough. I will definitely start checking the cable tension in the manner you discussed. As for the gear box and the kit you mentioned. Do you have the part number(s) of these items? If available, I may order the gearbox while on the road and hope it arrives be the time I get home. I would like to be able to quick turn the RV for a different trip. Once again, thanks for the info.
The kit number is 225008. That includes the motor 68ZY, motor mounting bracket 854291, gearbox actuator R25076 and flex drive shaft 854769. This is the compact high torque motor kit, 3/16 drive. It comes preassembled but can easily be disassembled to use any of the individual parts. Whether your buying the kit or an individual gearbox actuator, make sure you get an updated version with a serial number above 180xxxxxx. Now that I finally have both of my slides running quietly and efficiently, I’ll probably never need it, but at least I’ll have it if I do.
Attachment 1
