Old 09-27-2015, 07:40 AM   #1
Slides
Do you put your slides out before or after your jacks.
ostmd is offline   Reply With Quote
Old 09-27-2015, 07:45 AM   #2
fonzie's Avatar
most put out stab jacks out first and then slides......I do....
Fonzie
Old 09-27-2015, 07:49 AM   #3
nomad297's Avatar
No. But I always check level after I do deploy the slides, also, just in case.
Bruce
Old 09-27-2015, 07:58 AM   #4
NKARENG's Avatar
We level before putting out slides.
2016 Freedom Express 281rlds
2013 Flagstaff Micro Lite 25DS
2014 Dodge Ram 1500
Days Camped 2015 - 20
Days Camped 2016 - 12
NKARENG is offline   Reply With Quote
Old 09-27-2015, 08:06 AM   #5
Witch Doctor's Avatar
X'2, I'm always worried about not be level and binding a slide....Very easy to do if your not level...
Coachmen M/H
Concord
2018 / 300 DSC
Old 09-27-2015, 08:21 AM   #6
Islander's Avatar
To answer your question: slides out after stabilizing with jacks.
I have found that putting out the 2 slides (on the left side) always adds a little tilt to that side "if" I do not allow for it.
So I will always watch my level bubble to be 'high' (just a tad) on that slide side to make that allowance.
Hope this helps
Islander
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 Lariat DRW 4x4 7.3 Diesel 89k miles
Edge programmer, 4" SS exhaust turbo/back,
Tru-Cool Max Trans Cooler, Bilstein Shocks
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 09-27-2015, 09:35 AM   #7
Certified Curmudgeon
This excerpt from the manufacturers manual on the subject:
EXTENDING SLIDEOUT ROOM
1. Level the unit.
2. Verify the battery is fully charged and hooked-up to the electrical
system.
3. Remove the transit bars (if so equipped).
4. Press and hold the IN/OUT switch (Fig. 1B) in the OUT position until
the room is fully extended and stops moving.
5. Release the switch, which will lock the room into position.
Note: Motorhomes do not have stabilizers like those found on towable products.
Mike Dropped
Old 09-27-2015, 09:37 AM   #8
muddyrode's Avatar
Drop level and slides go out last
2016 SANDPIPER 35ROK
2013 Silverado Duramax 3500HD DRW LB
Stop worrying about the potholes in the road and enjoy the journey
muddyrode is offline   Reply With Quote
Old 09-27-2015, 10:57 AM   #9
That is the way I have always done it. This weekend the guy next to me said he does it slides first. Just looking for the pro's and con's
Old 09-27-2015, 11:05 AM   #10
Sev
I always level first then push out the slides.
You do not want the slides to bind as there have been several early reports of slides breaking then having to manually push them back in.
The less stress you can put on the slides the better. If they are level before deploying this will reduce any issues that may arise.
Sev is offline   Reply With Quote
Old 09-27-2015, 03:45 PM   #11
In the FR3 if im on level ground and am not unhitching the tow vehicle on dolly, I will generall manually lower the jacks to stabalize the chassis (drop them just to where they start to unload suspention. Then i will do my slides. If we are unloading the tow first then i do the auto level and then slides. Never had an issue with the slides except the bedroom gear box eating a tooth 2 months after buying it. That was tell before i ever tried the slides out not on level jacks. Seems not to make much difference. I wouldnt put them out if it was way off level...but ive been more than 5degree off with them in/out. The gear failure was from bad gears not from slide /level issues.
zippyzrx is offline   Reply With Quote
Old 09-27-2015, 04:45 PM   #12
Can you tell me is hydraulic reservoir suppose to be full? Excuse me I know nothing about the workings of my RV.
rrschmidt8 is offline   Reply With Quote
Old 09-27-2015, 08:56 PM   #13
1/2 inch from the top with ALL rams retracted.
Mike Dropped
slide, slide out
