Old 09-27-2015, 07:40 AM   #1
Do you put your slides out before or after your jacks.
ostmd is online now   Reply With Quote
Old 09-27-2015, 07:45 AM   #2
fonzie's Avatar
most put out stab jacks out first and then slides......I do....
Nights Camped: 2011(21) 2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36)
Old 09-27-2015, 07:49 AM   #3
nomad297's Avatar
No. But I always check level after I do deploy the slides, also, just in case.
Old 09-27-2015, 07:58 AM   #4
NKARENG's Avatar
We level before putting out slides.
2016 Freedom Express 281rlds
2013 Flagstaff Micro Lite 25DS
2014 Dodge Ram 1500
Days Camped 2015 - 20
Days Camped 2016 - 12
NKARENG is offline   Reply With Quote
Old 09-27-2015, 08:06 AM   #5
Witch Doctor's Avatar
X'2, I'm always worried about not be level and binding a slide....Very easy to do if your not level...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Witch Doctor is online now   Reply With Quote
Old 09-27-2015, 08:21 AM   #6
Islander's Avatar
To answer your question: slides out after stabilizing with jacks.
I have found that putting out the 2 slides (on the left side) always adds a little tilt to that side "if" I do not allow for it.
So I will always watch my level bubble to be 'high' (just a tad) on that slide side to make that allowance.
Hope this helps
'07 WildCat 30 RLBS ~ West Coast Edition ~
Trail Air - Tri Glide Pin Box
2000 F350 DRW 7.3 Diesel Lariat 89k miles
Edge programmer, 4" SS exhaust turbo/back
Vancouver Island, B.C., Canada
Islander is offline   Reply With Quote
Old 09-27-2015, 09:35 AM   #7
Former Full Timer
Duckogram's Avatar
This excerpt from the manufacturers manual on the subject:
1. Level the unit.
2. Verify the battery is fully charged and hooked-up to the electrical
3. Remove the transit bars (if so equipped).
4. Press and hold the IN/OUT switch (Fig. 1B) in the OUT position until
the room is fully extended and stops moving.
5. Release the switch, which will lock the room into position.
Note: Motorhomes do not have stabilizers like those found on towable products.
The recipe for perpetual ignorance is:
Be satisfied with your opinions
and content with your knowledge.
Elbert Hubbard
Old 09-27-2015, 09:37 AM   #8
muddyrode's Avatar
Drop level and slides go out last
2012 wildcat sterling 32RL
2013 3500HD DRW Silverado Duramax
muddyrode is offline   Reply With Quote
Old 09-27-2015, 10:57 AM   #9
That is the way I have always done it. This weekend the guy next to me said he does it slides first. Just looking for the pro's and con's
Old 09-27-2015, 11:05 AM   #10
I always level first then push out the slides.
You do not want the slides to bind as there have been several early reports of slides breaking then having to manually push them back in.
The less stress you can put on the slides the better. If they are level before deploying this will reduce any issues that may arise.
Sev is offline   Reply With Quote
slide, slide out
