Old 10-29-2014, 09:59 AM   #1
sliding door in fr3 motor home
Sliding door between bath and kitchen in hallway- would like to close this door off as to help cool area with indash ac only in the summer- any ideas how to fix a latching system that looks good and works to hold the door closed?
Lfrazee is offline   Reply With Quote
Old 10-29-2014, 11:27 AM   #2
leisurelarry's Avatar
Mine holds quite well surprisingly with the supplied lock from FR.Click image for larger version
Name:	ImageUploadedByForest River Forums1414599958.884978.jpg
ID:	65526Click image for larger version
Name:	ImageUploadedByForest River Forums1414600010.037543.jpg
ID:	65527Click image for larger version
Name:	ImageUploadedByForest River Forums1414600047.509532.jpg
leisurelarry is offline   Reply With Quote
Old 10-29-2014, 01:19 PM   #3
StephanFR3's Avatar
Oh I like that. What's the part numbers?
StephanFR3 is offline   Reply With Quote
Old 10-29-2014, 02:35 PM   #4
Not sure of the part # StephanFR3. I have a 2015 bought in May manufactured in April. Perhaps ForestRiver could be of some help with this. It looks like a pretty standard piece of hardware for a pocket door which could be found at any Home Depot or Lowes.
Old 10-29-2014, 02:36 PM   #5
mud yapster's Avatar
That does look nice
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 10-30-2014, 05:00 PM   #6
HAPPY WHEN RV'ING
drivmsafe's Avatar
One thing you might want to consider is to hang a thick blanket down from the forward bunk. This will help to keep the ac from blowing into the kitchen area. We use two so my wife is able to exit to the kitchen if need be. Yes, it's a pain, but it works.
If you don't want to do this, consider running the coach ac while driving. Yes, you'll need to run the generator while doing this.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 10-31-2014, 06:37 AM   #7
We have the 25 that does not have a door to isolate the bedroom so I added a wood closet rod and a large heavy drape that looks like factory original. Stained the wood to match and it gives you privacy and darkness where needed.
For the front we have used the blanket hanging from the top bunk for both heat and cold and it works real well. The cab heater is not much good when it is 20 degrees outside!
Enconcapt is offline   Reply With Quote
Old 11-02-2014, 06:58 AM   #8
Technorick's Avatar
014 30DS. Mine has the primitive door lach lock found on many boats and the recessed cup. It's amazing to me
Technorick is offline   Reply With Quote
Old 11-02-2014, 07:01 AM   #9
Technorick's Avatar
Amazing to me that these alike models have such different hardware. Also mine has no way to lock or latch from the inside. Just the ability to latch open for driving.
Name:	ImageUploadedByForest River Forums1414929634.952258.jpg
Name:	ImageUploadedByForest River Forums1414929659.432717.jpg
Old 12-15-2014, 11:58 AM   #10
Originally Posted by leisurelarry View Post
Mine holds quite well surprisingly with the supplied lock from FR.Attachment 65526Attachment 65527Attachment 65528
can you still lock the door open?
welder is offline   Reply With Quote
Old 12-15-2014, 01:04 PM   #11
Yes you can still hold (lock) the door open with the factory supplied strap attached on the shower side of the doorway.Click image for larger version
Name:	ImageUploadedByForest River Forums1418666472.555688.jpg
ID:	67582Click image for larger version
Name:	ImageUploadedByForest River Forums1418666506.436709.jpg
ID:	67583Click image for larger version
Name:	ImageUploadedByForest River Forums1418666528.305375.jpg
ID:	67584Click image for larger version
Name:	ImageUploadedByForest River Forums1418666552.174562.jpg
It works very well and keeps the door quietly tucked away in the pocket while driving.
Old 12-16-2014, 01:31 PM   #12
HAPPY WHEN RV'ING
drivmsafe's Avatar
Instead of going to all the trouble of installing a door latch/lock to keep the door open while traveling, I bought one of those inexpensive rubber door stops. If I want the door closed I just wedge the stop in the opening, and presto, door stays closed.
Old 12-23-2014, 10:32 AM   #13
Yea dealer got parts same as the newer models and installed it for me- now I can lock my door in the concealed wall or in the full closed off position , providing privacy from front to rear and to save on dash air cooling square footage.
door
