Old 07-10-2017, 10:21 PM   #1
DaRealDeal77's Avatar
Slow Water Pressure
Hello everyone! I'm having issues with my kitchen faucet, the water is down to a trickle. Check the water pressure gauge, the water filter, took off the aerator and cleaned it, still nothing. The shower pressure is good, the bathroom sink, and toilet water flow perfect. Any suggestions? Do I have to take my new FR3 to the DR. Or can I fix it myself?
Nelly
DaRealDeal77 is offline   Reply With Quote
Old 07-10-2017, 10:42 PM   #2
King of the Road
If it just started but was fine before something may be in the lines or they got pinched or something. Is it the same for hot and cold?
2016 Crusader Lite
Single slide
2013 Ram 2500 Crew Cab Tow Vehicle
2016 days camped = 91, 2017 days camped = 109
Dano1955 is offline   Reply With Quote
Old 07-11-2017, 10:48 AM   #3
Hi Dano1955, yes is both hot and cold. There is so much stuff in the cabinets to remove in order to look at the pipes. I'm concerned if I play with the connection it may get worse. And we are not even near our dealer in Florida. We are in Washington State right now.
Old 07-11-2017, 11:14 AM   #4
You are in a RV that is meant to Travel! Any F/R Dealer "Should Help" if Not Call F/R Division whereyour FR3 was built and secure Permission to use Any Dealer or Mobile Service just need F/R to give you a Warr Repair # so you can "Get Your $$ Back" From F/R! Youroo!!
Old 07-11-2017, 11:49 AM   #5
King of the Road
Just my thoughts on this, if it's both hot and cold lines and it was good before, it is probably not the water lines (unless something in the cabinet has pinched both lines) but rather something about the faucet or valves that the water lines are connected to.
You've checked the aerator and cleaned it out, but what happens if you leave the aerator off? Try running some water with it off, if you still have the problem, maybe try running a wire down through the faucet to see if it might be blocked.
2016 Crusader Lite
Single slide
Old 07-11-2017, 12:22 PM   #6
HAPPY WHEN RV'ING
drivmsafe's Avatar
You can take your FR3 to any authorized FR dealer in any state. they'll contact FR for authorization.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 07-11-2017, 12:42 PM   #7
King of the Road
btw does this happen on both fw tank and city connection?
2016 Crusader Lite
Single slide
Old 07-11-2017, 12:54 PM   #8
clr
Is this a single handle type of faucet? If it is a single handle the cartage in the center of the faucet may be plugged by stuff. You can remove the handle and then remove the cartage and see if it is blocked. You could just call a mobile RV repair guy and have him do it since you are still under warr.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is offline   Reply With Quote
Old 07-11-2017, 01:19 PM   #9
2015 FR3
JEGNCJG's Avatar
Turn the water off take the Valves off in the kitchen both hot and. cold and clean the valves . I found little pieces of plastic in mine
JEGNCJG is offline   Reply With Quote
Old 07-11-2017, 01:51 PM   #10
There is a little screen that screws onto the bottom of the water pump, or inline with it. Check that to see if its clogged. Did you just de-winterize it or this just started out of the blue? Pump running (should feel vibration)?
Mike
2015 FR3 30DS
KansasFR3 is offline   Reply With Quote
Old 07-11-2017, 03:04 PM   #11
Thanks to everyone for all their responses, I will try all of the above, and if all that fails, I will contact FR for a dealer near me!
Old 07-24-2017, 05:54 AM   #12
Orider's Avatar
Plugged kitchen faucet
I found my kitchen faucet to be almost not running at all. I unscrewed the filter at the end and cleaned all the debris from the screen. That fixed it.
Try that first.
Orider is offline   Reply With Quote
Old 08-03-2017, 01:42 AM   #13
Just wondering if you did like a winterizing with compressed air set to 40 lbs and see if you can blow out any debris but you will need a fitting on the city water inlet!You can buy what you need from camping world...just a thought!
lazbo is offline   Reply With Quote
pressure, water
