Old 03-21-2018, 08:32 AM   #11
How did you get the sofa bed out that came with the RV?
ShelleyB is offline   Reply With Quote
Old 03-21-2018, 09:11 AM   #12
It will fit through the door. It is tight but will go.
Fredsusanshag is offline   Reply With Quote
Old 03-21-2018, 09:42 AM   #13
How do you take it apart?
Old 03-21-2018, 10:19 AM   #14
Papaduck's Avatar
The back is not secured with any fasteners (e.g. screws or brackets). It fits/slides together much like sliding 2 forks together on on each side. It was a tight fit, so you will have to apply some upward force and wiggle to get the back and base to separate.
Chuck & Donna
U.S. Army - Retired
2016 FR3 30DS w/2016 Chevy Colorado Toad
Days Camped: 2017 - 45, 2018 - 52, 2019 - 28
Papaduck is offline   Reply With Quote
Old 03-21-2018, 11:23 AM   #15
I just took the cushions off and zip tied the bed so it would not spring out. I screwed 4 L brackets from the floor and took it out the door. It is heavy and takes two people to do it. Also I unscrewed the door bracket at the bottom of the door so the door would open further.
Old 05-22-2018, 09:37 PM   #16
How hard was it to get the recliners inside the coach? Does the back separate from the base? Are they expensive?
Sgtmac is offline   Reply With Quote
Old 05-23-2018, 06:39 AM   #17
Sofa replacement
New recliner came in several pieces. The base was the largest and it fit thru the door with no issues. The recliner was $499 thru amazon. Homelegance double reclining loveseat brown bonded leather.
Old 05-23-2018, 09:20 AM   #18
Papaduck's Avatar
Our recliners also came in several pieces. All pieces fit thru the door with no issues.
Chuck & Donna
U.S. Army - Retired
Old 05-23-2018, 04:46 PM   #19
I have a Jackknife sofa directly across from a queen sleeper sofa. Queen sofa sleeper is comfortable but you can't use both at the same time due to space limitations. Inspired by your post I found these on Amazon. I may have to rig a cargo strap or something for transit operations. What do you think? Click image for larger version
Coleman Tent, 2001 Coleman Pop-up, 2006 Fleetwood Pioneer 280BH. 2017 Coleman Lantern 300TQ Toy Hauler, current home away from home: 2008 Forest River Georgetown 373DS.
Trickdog is offline   Reply With Quote
Old 06-19-2018, 09:05 PM   #20
Originally Posted by Papaduck View Post
Here's a picture of ours installed.
Could I ask you the length of your recliner sofa? I love the look of yours but we’re having a hard time finding one that will fit in our 3011DS slide. Thanks
Gaga1951 is offline   Reply With Quote
replacement
