Old 02-08-2018, 03:17 PM   #1
Sofa replacement with double recliner and seat replacement
I am in the process of removing my sleeper sofa and replacing with double recliner No console. Ordered recliner from amazon $599 free delivery. Will post pics when finished. Also replace drivers and passenger seat with Flexsteel seats. Feels like I am seating on a cloud. I can drive all day and not get tired. Worth every penny.
Fredsusanshag is offline   Reply With Quote
Old 02-08-2018, 08:53 PM   #2
Papaduck's Avatar
I'm also in the process of swapping out my 30DS sofa sleeper for a set of Thomas Payne Recliners with center console. I got the idea from a previous post under "Modifications and Updates (http://www.forestriverforums.com/for...ts-144155.html). My dealer's going to perform the swap next Tuesday.
Chuck & Donna
U.S. Army - Retired
2019 Georgetown GT5 31R5 w/2016 Chevy Colorado Toad
Days Camped: 2017 - 45, 2018 - 52, 2019 - 70, 2020 - 32, 2021 - 16
Papaduck is offline   Reply With Quote
Old 02-18-2018, 09:51 AM   #3
Harleyreb's Avatar
Fred,
Do you have a website and or part numbers for the Flexsteel seats you ordered?
2015 FR3 30DS
2020 Jeep Gladiator
Harleyreb is offline   Reply With Quote
Old 02-19-2018, 01:07 AM   #4
What colour brown is that as I have seen a few...did you have problems swapping out and anchoring to slide?
lazbo is offline   Reply With Quote
Old 02-19-2018, 10:04 AM   #5
Papaduck's Avatar
It's called "Majestic Chocolate" in the Thomas Payne Collection. The brown is slightly darker than the original sofa color.
As for installation, the back of the sofa comes off by sliding it up and was removed through the door. It's attached to the slide with only 2 "L" brackets and 4 screws. The recliners are attached to each other much like a sectional sofa and secured with 4 screws on each recliner. No penetration through slide floor.
Chuck & Donna
U.S. Army - Retired
Old 02-19-2018, 10:07 AM   #6
Papaduck's Avatar
Here's a picture of ours installed.
Chuck & Donna
U.S. Army - Retired
Old 02-25-2018, 01:53 PM   #7
No problem it went right in used the old L brackets that held down the sofa and secured to the frame of the recliner.
Old 02-25-2018, 01:56 PM   #8
Coach supply direct
69039 elkhart road
edwardsburg, mi 49112
800.589.7251
2 554 busr
554busr ultraleather flexsteel
captains chairs with adjustable arms
and skirt
1 power lumb... Driver side power lumbar option
2 brisa ultral... Covered in lasso distressed brisa
ultraleather
Old 02-25-2018, 01:57 PM   #9
2 554 busr
and skirt
ultraleather
Old 03-01-2018, 09:56 PM   #10
Thanks guys for your input...much appreciated
Old 03-21-2018, 08:32 AM   #11
How did you get the sofa bed out that came with the RV?
ShelleyB is offline   Reply With Quote
Old 03-21-2018, 09:11 AM   #12
It will fit through the door. It is tight but will go.
Old 03-21-2018, 09:42 AM   #13
How do you take it apart?
Old 03-21-2018, 10:19 AM   #14
Papaduck's Avatar
The back is not secured with any fasteners (e.g. screws or brackets). It fits/slides together much like sliding 2 forks together on on each side. It was a tight fit, so you will have to apply some upward force and wiggle to get the back and base to separate.
Chuck & Donna
U.S. Army - Retired
Old 03-21-2018, 11:23 AM   #15
I just took the cushions off and zip tied the bed so it would not spring out. I screwed 4 L brackets from the floor and took it out the door. It is heavy and takes two people to do it. Also I unscrewed the door bracket at the bottom of the door so the door would open further.
Old 05-22-2018, 09:37 PM   #16
How hard was it to get the recliners inside the coach? Does the back separate from the base? Are they expensive?
Sgtmac is offline   Reply With Quote
Old 05-23-2018, 06:39 AM   #17
Sofa replacement
New recliner came in several pieces. The base was the largest and it fit thru the door with no issues. The recliner was $499 thru amazon. Homelegance double reclining loveseat brown bonded leather.
Old 05-23-2018, 09:20 AM   #18
Papaduck's Avatar
Our recliners also came in several pieces. All pieces fit thru the door with no issues.
Chuck & Donna
U.S. Army - Retired
Old 05-23-2018, 04:46 PM   #19
I have a Jackknife sofa directly across from a queen sleeper sofa. Queen sofa sleeper is comfortable but you can't use both at the same time due to space limitations. Inspired by your post I found these on Amazon. I may have to rig a cargo strap or something for transit operations. What do you think? Click image for larger version
Coleman Tent, 2001 Coleman Pop-up, 2006 Fleetwood Pioneer 280BH. 2017 Coleman Lantern 300TQ Toy Hauler, current home away from home: 2008 Forest River Georgetown 373DS.
Trickdog is offline   Reply With Quote
Old 06-19-2018, 09:05 PM   #20
Could I ask you the length of your recliner sofa? I love the look of yours but we’re having a hard time finding one that will fit in our 3011DS slide. Thanks
Gaga1951 is offline   Reply With Quote
replacement
