Old 01-28-2017, 12:13 AM   #1
AD2
Some things I discovered today
Today I decided I should change the oil in the engine and the gen set in my 28ds. The rig has just a touch over 3,000 mile and the generator has 10 hours on it. So I rounded up oils, filter and grease gun, went out back where I park the motor home and started to move it into my manufacturing facility where it is warm. I keep my unit plugged in to shore power and I run an electric heater inside even though it has been winterized.
I unplugged the power cable and hopped into the drivers seat and reached down to start the engine and felt a cold blast of air coming from air outlets on the dash. I was very surprised about that. As I was warming up the engine I noticed the button that illuminates when the dash environmental controls is in circulate was off. So I put it in recirculate mode hoping when the engine is off the damper stays closed cutting off the cold air.
I changed the engine oils, filter and greased the front end, putting engine oil into the filler neck with a small funnel jammed up against the bottom of the dash was discovery one. As I was twisted around trying to hold the funnel, not hit my head or spill the oil all over I happened to look up and saw the ductwork that feeds air to the defroster ducts. Discovery number two. The flexible ductwork that exits the radiator shroud and baffles connected to the chassis environmental system running to the defrosters on the dash is wire reinforced NON INSULATED flexible duct. Well no wonder the defrosters don't work and the front of the coach is either hot in the summer or cold in the fall. Those ducts are forward of the radiator where they act as nice little heat exchangers to the ambient conditions they are subject to. So the fix is to insulate the existing, replace them with insulated duct, or find something to lay over the defrosters while parked.
Anthony & Amy Dennis
AD2 is offline   Reply With Quote
Old 02-01-2017, 01:52 PM   #2
Interesting info.. I've had similar problems with my 2017 -30 FR3 (hot in summer /cold in winter) ..I'll have to check my ducts out when I get the rig back from maintenance shop..
BILL49 is offline   Reply With Quote
Old 02-03-2017, 04:54 PM   #3
AD2
ID:	129119Click image for larger version
ID:	129120Click image for larger version
ID:	129121Click image for larger version
I received a request to post some pictures of the defrost ductwork so I popped the front grill cover open and took these. The foamed in place area's are the connections to the defrost register in the dash by the base of the windshield.
Old 03-03-2017, 02:03 PM   #4
Hi
In the very last picture I see what I think is the blend door actuator, Can you confirm that its. I have a 2014 fr30 and I'm looking for the location the blend door and haven't been able to find it so far.
perrior is offline   Reply With Quote
Old 03-03-2017, 02:11 PM   #5
Originally Posted by perrior View Post
Hi
In this case (in the photo) it is actually a blend valve.
It is a servo actuated valve in the heater hose line that regulates the amount of coolant that flows through the heater core. It is actuated by the climate control temperature knob setting.
Days Camped: '17=30 '18=51 '19=58 '20=14
Old 03-03-2017, 02:20 PM   #6
blend door
Thank you so much for the fast reply and I understand what you said..
I'll continue to search for what I am looking for as my engine heater blows warm air and the temp control has no effect on changing the temp.. All of my searches have been tried on blend door actuator so maybe I should try temperature door actuator..
Thanks again
Bob
cover
