11-14-2018, 03:12 PM
#21
Thanks for the great knowledge & Feedback... Ford will be taking a look at it an i will report back !!!
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30:2022 46:2023 47:2024 7
11-16-2018, 07:31 AM
#22
Unlike the old gear driven speedos, the new speedometers can be calibrated for different tire size, etc.
Years ago, I had a Pontiac with a 3-speed auto trans. I had it changed out to a 4-speed auto trans. I was on a two-lane road between cities heading for a reserve meeting. I came up behind this county sheriff on a two-lane highway.
By my speedometer, he was doing 40 MPH. So, I passed him. And so, on came the gumballs. He indicated that I was driving 15 miles over the speed limit. A total surprise to say the least. I explained my speed and questioned, would I be dumb enough to pass a marked squad car and be asking for a ticket? Being reasonable, he asked if I had changed tires or made a change to the car. Yes, I changed transmissions. He gave me a pass and then drove ahead of me to indicate when I was doing the proper speed limit. The speedometer was off and I had to change the gears on the transmission. It's a lot different today.
11-16-2018, 08:20 AM
#23
Originally Posted by formerFR
time it between milepost - if you hit a mile in 1 minute, then you know you're traveling
60 miles per hour
Originally Posted by n0ms
This is the correct test. Reset the trip odometer also at the start. Math doesn’t lie .
But DON'T use the odo to determine your mile. If the speedo is off, the odo will be off, too, as Bluepill said in Post #10.
Use an interstate that has mile markers, or find an actual test area.
2011 Traverse LT, 3.6L, FWD
12-15-2018, 06:50 AM
#24
Use a gps . It will give you an actual speed reading as you drive .
12-15-2018, 06:56 AM
#25
Almost all ford trucks are off 3 to 4 mph ! If your speedo says 50 you are probably going 47 !
12-15-2018, 08:03 AM
#26
Both of my Ford trucks speedometers are spot on compared with the Garmin.
Tom & Renée
Durham, NC
2021 Jayco Class C model 27U
12-17-2018, 09:55 AM
#27
Appointment is this Friday will report back what is at issue. Thanks for all the feedback
Days Camping
01-22-2019, 12:40 AM
#28
Just wanted to follow up on this. Just FINALLY found a Authorized Ford Location that would work on my FR3 Warranty. Took them about 2 bourse but did find out that the axle and tire size was not programmed correctly. They fixed the issue by reprogramming. No cost ...
Days Camping
01-22-2019, 08:22 AM
#29
These Ford settings (and many others) are accessible in the computer via the OBD2 port, a $25 data connector, your Windows laptop, and free Forscan software. A surprising number of things are controlled this way and each chassis model is different so ya gotta know what addresses to change. F150/Expeditions are fairly well documented and I suspect the motorhome chassis have been worked out by not too.
On my '17 Expedition I activated DRLs, extinguished excessively bright fog light indicators on the dash display, and added engine hours/idle hours to the dash display. The F150s can be set on some years to show individual tire pressures and other items. Worth exploring of you have a Ford chassis.
-- Chuck
01-22-2019, 08:26 AM
#30
-- Chuck
I'm going to look into this for my F-150, I know there are some settings i'd love to get my hands on without going to the dealer. Any specific cable you recommend or is just an OBDII to USB?
Travel Trailer: 2004 Flagstaff 25LB
New Tow Vehicle: 2017 F-150 3.5 Ecoboost, supercrew short bed FX4 Lariat
Old Tow Vehicle: 2009 Silverado 2500HD 4x4 Ext. Cab Short Bed
Travel Pooch:Sophie the Sato - Cats: Rhody and Hazy
2018:22nights / 2019:31Nights / 2020:18Nights
01-22-2019, 09:00 AM
#31
I prefer a wired connection so I bought the OHP ELMconfig Forscan OBD2 Adapter. <--- that's a link. $30, not $25 (sorry).
Lots of Forscan information on the F150 forum(s). Speedo correction is a common one.
Download Forscan and register (free) for the extended version so you can change more things than just the few in the standard version.
Forscan is a Windows only program (to my knowledge).
-- Chuck
01-22-2019, 09:06 AM
#32
-- Chuck
Cool, thanks, if that one works for you then that's the one I'll get.
I've gone a long time without a windows computer but my wife and I both have one that we needed for programs at work, so I can finally use stuff like this.
