Little update on the stairs. Kwikee Kwik Lube did the trick on the stairs, creak free even with the 240lb manchild that walks like King Kong using them. It's a grease based spray with the same qualities as a silicone based spray, water displacement, rust/corrosion prevention, but is supposed to not attract dirt. It's actually made specifically for this type of usage amongst others. I'll hit the jacks in the coming week.
