Old 09-01-2018, 06:04 PM   #1
Steering Stabilizer
I have a 2017 FR3 32DS. Can someone tell me what bracket kit they used on a roadmaster reflex RSSA Steering Stabilizer. I ordered a RBK25 kit and it does not fit. There are two other kits, RBK 9 and RBK 22 and don't know which one to order.
csmfish is offline   Reply With Quote
Old 09-01-2018, 09:24 PM   #2
CC Traveler's Avatar
I ordered the RBK 9 kit and it works. My chassis was a 2016 for a 2017 coach. Below is what the Roadmaster Application Guide note says for the RBK 9 Kit use:
--For coaches with V10 engines. The RBK sku listed is for the mounting kit only. Be sure to order this AND the steering stabilizer part number RSSA.--
The other 2 kits have GVWR of 24,000 or 26,000. Our 30DS is rated at GVRW 18,000 lbs. Take a look at the coach stickers on your drivers side wall for weight and chassis date.
Hope this helps.
Mark & Connie
2023 Coachmen Concord 321DS
2006 GMC Canyon (Toad)
CC Traveler is offline   Reply With Quote
Old 09-01-2018, 10:20 PM   #3
Steering Stabilizer
I checked and my chassis was a 2016 also for my 2017 coach. Guess I ordered the wrong kit. Did you mount yours on the Drivers side or on the Pass side.
Thanks for the info.
Old 09-02-2018, 12:32 AM   #4
I mounted it on the passenger side. After I got it mounted it took a couple of short road test to get it adjusted properly, but seems to really help.
Mark & Connie
Old 09-02-2018, 09:17 PM   #5
Steering Stabilizer
Thanks again, will get the right bracket on Tuesday.
Darrel and Gayle
2017 FR3
2008 Jeep Rubicon Toad
