Old 01-18-2015, 07:29 AM   #21
Online_17's Avatar
Makes you wonder...if the CHF was an obvious improvement and simple to do, then why wouldn't the manufacturer do it?
Online_17 is offline   Reply With Quote
Old 01-18-2015, 03:28 PM   #22
Bobb36's Avatar
found this
I asked the Ford Engineer that very question and the response made sense. They only make the "Stripped" chassis. This means anything could be put on the top of those frame rails (ie: flat bed, box truck, etc). They don't set it up specifically for MH customers. It would be up to the MH manufacturers to make the mod.
in this thread: Ford Chassis Questions
2014 FR3 30DS
2014 JEEP WRANGLER WILLYS
Bobb36 is offline   Reply With Quote
Old 01-18-2015, 07:58 PM   #23
So far will worth the money !!
bigdocron is offline   Reply With Quote
Old 01-18-2015, 08:11 PM   #24
hey bigdocron, give us some details !!
what did the t-plus give you
did you keep the CHF, or did you reverse back to stock
svwc is offline   Reply With Quote
Old 01-18-2015, 08:23 PM   #25
CW installed and got everything aligned ,took most of the sway and over steering out of it .Getting ready for a longer trip in 2 wks ! I'll let you know if all is well . Nothing was changed by CW
Old 02-01-2015, 03:01 PM   #26
I just completed the Cheap Handling Fix and installation of a Roadmaster Reflex steering stabilizer on my 2015 FR3 25DS. I am very pleased with the results. The steering 'wander' is pretty much gone and the greatly reduced swaying makes for much better handling in turns etc. I have only done a short test drive without the toad, but am planning a 3000+ mile trip at the beginning of March and will really tell me how much better it is.
FR3-25DSOwner is offline   Reply With Quote
Old 02-01-2015, 06:03 PM   #27
Why did you go with the road master system as compared to the safe t plus system?
Did you do the CHF on both front
& rear ?
Sent from my rotten iPhone
Old 02-01-2015, 06:11 PM   #28
& rear ?
I chose the Roadmaster product primarily on cost. The basic principle of operation was the same as some others, but this appeared to be the lowest cost. It was simple to install and I made sure the wheels were pointed straight ahead prior to installation and I lucked out and did not have to do any further adjustments to get it to track straight. I did the CHF on both front and rear and retained the original struts on the front, despite the ongoing debate on whether to get longer ones or not.
Old 02-01-2015, 07:36 PM   #29
Don't have the FR3 but have the Coachmen Pursuit and I installed the Roadmaster RSSA and did the cheap handling fix. Last week I took the coach out to the factory service center for some repairs. Had the tow dolly and a Chevy Silverado Pick up on it and found the Roadmaster stabilizer to make a huge difference. Drove most of the time with one hand. Last August on the way to the FROG rally and a lighter vehicle on the dolly it was a two hand drive. Went with the Roadmaster because I found one with the mounting bracket for less then $240.00 including shipping. Took approximately 30 minutes to install it.
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is online now   Reply With Quote
Old 02-01-2015, 07:58 PM   #30
fpo1123's Avatar
Has any one figured out how to take up the slack in the steering on the fr3. I did the cheap fix and safety plus. Still some slack in the steering. No problem with passing trucks or wind, just seems loose in the steering wheel.
fpo1123 is offline   Reply With Quote
